Which 1.6 rocker for Lt4 Hotcam?
Old Jan 10, 2022 | 01:45 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Looking to swap from 1.5 rockers for some 1.6 to run true hotcam lifts. I know I will have to drill out the pushrod holes. Anybody know what size drill bit needed? What is the best 1.6 rocker to use . Was hoping to use roller type but read that they wont fit under cb vc's. So I read that regular 1.6 work best . Part Number?
Old Jan 10, 2022 | 01:10 PM
BOOT77's Avatar
Re: Which 1.6 rocker for Lt4 Hotcam?
Do you have guideplates or need self aligning rockers? What heads? More info is always better.
Old Jan 10, 2022 | 02:37 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Nope no guide plates. They are Vortec heads on a crate GM L31. Think 906, haven't checked in a while.
Old Jan 10, 2022 | 03:08 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
https://www.gmperformancemotor.com/parts/19210729.html
I have no idea if they will fit under you valve covers,… many valve covers need to be ‘modified’ to accommodate roller rockers.
Old Jan 10, 2022 | 03:21 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Whoa those are niceeee. But way out of my budget. Was looking at these two. I'm pretty sure these will work but want to hear from someone who has run a set.
https://www.summitracing.com/parts/s...RoCnXEQAvD_BwE
https://www.summitracing.com/parts/s...BoCkOYQAvD_BwE
Old Jan 11, 2022 | 10:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
https://www.summitracing.com/parts/cca-1418-16
ive run these on L98 centerbolt valve covers just fine.
Old Jan 11, 2022 | 05:57 PM
John in RI's Avatar
If you're gonna' go RR's,....... forget roller tip & go full ( STEEL ) RR's !!!
Old Jan 11, 2022 | 06:16 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I’m running a set of scorpion narrow body full rollers under stock vortec valve covers. 1.5s though
tony_cogliandro
May 16, 2009 12:17 PM
84z28350
Apr 19, 2007 05:07 AM
tummyson
Jun 15, 2006 11:16 PM
Tim Hunsinger
Jan 23, 2005 10:19 PM
TBI92Camaro
Dec 28, 2004 12:07 AM
