Enough vacuum?
Old Mar 11, 2023 | 10:32 AM
Andreas_91GTA's Avatar
Car: Trans Am GTA 1991
Engine: L98 with Super Ram and Fitech
Axle/Gears: 3.23:1
Enough vacuum?
Switched to an Accel super ram and feels it's a little bit hesitant to idle. It starts but....i dont know....doesnt feel as on-it's-toes like it did with the old GM tpi-setup. It pulls 17 hg vacuum, just in the green on my tester. Since there's a lot of snow im just in the garage testing stuff out. I have no idea how it feels on the road.
Everything is torqued, rtv'd, re-torqued and triple checked but I'd like to see that vacuum to 18-20.. im testing without hvac vacuum line and egr delete. All unused nipples are plugged.
What's left to do? Smoke test?
Old Mar 11, 2023 | 12:22 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Enough vacuum?
What was the vacuum reading with the original manifold?...
Old Mar 11, 2023 | 12:48 PM
Axle/Gears: 3.23:1
Re: Enough vacuum?
Wish I knew. The real difference is cold starting where the original just started really strong and the super ram wants some throttle first 5 seconds to not stall.
Old Mar 11, 2023 | 03:48 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Enough vacuum?
Smoke test it for leaks if you think it's an issue. Was this a stock cam engine? It may just need a tune.
Simple smoke machines can be bought relatively inexpensive. Made up for even cheaper or borrowed too. Asking a local shop to do it is sometimes an option.
Old Mar 11, 2023 | 06:27 PM
Axle/Gears: 3.23:1
Re: Enough vacuum?
Yep, stock cam. Can't really think of anything else other than a small leak making it behaving like this. I have resetted the IAC, triple checked every connection and replaced all vacuum hoses.
Kind of prefer a major issue than this (guessing) sneaky leak somewhere
Needle on the vacuum gauge is steady at 17. But, maybe it was at 17 before I tore it down.
Old Mar 11, 2023 | 08:20 PM
NoEmissions84TA's Avatar
Re: Enough vacuum?
Hose pinch off pliers:
Amazon.com: 3 Pack Hose Pinch Off Pliers, Clamp Set in 3 Sizes for Radiator, Brake, Coolant, and Fuel Lines, Red : Automotive Amazon.com: 3 Pack Hose Pinch Off Pliers, Clamp Set in 3 Sizes for Radiator, Brake, Coolant, and Fuel Lines, Red : Automotive
Pinch off your new vacuum hoses one at a time and watch for any differences in the gauge reading.
Old Mar 12, 2023 | 05:54 AM
Axle/Gears: 3.23:1
Re: Enough vacuum?
I dont know what im suspecting. Today after 5 min running the idle started to wander all over the place. Could it be something temperature related?
Old Mar 12, 2023 | 10:51 AM
Re: Enough vacuum?
What donyou mean by wandering? Like a surging? Vacuum leaks can cause that.
Old Mar 12, 2023 | 11:04 AM
Axle/Gears: 3.23:1
Re: Enough vacuum?
Yes, surging. When the rpms dropped so did the vacuum. I guess it's the IAC letting air in keeping it running? It was going (guessing) between 500 and 1000 rpm a couple of times. This is when it was up to operating temp. On its way to operating temp it was stable.
I should mention my problem isn't super high idle. Problem is it does not wanna start as strong as before the intake change.and that's what's bugging me.
And I haven't driven it yet. Maybe other stuff will happen when the engine is under load.
Old Mar 18, 2023 | 06:53 AM
Axle/Gears: 3.23:1
Re: Enough vacuum?
Bought a smoke machine and found a loose bolt holding the throttle wire bracket. Should've checked it and saved money but oh well...."learning investment". Now it's pulling 19-20 hg and starts right up.
caddyescalade
Aug 26, 2021 01:48 PM
mr z28
Brakes
Sep 23, 2014 03:34 PM
sellmanb
Oct 7, 2004 08:05 PM
jfreeman74
Jan 18, 2003 05:44 AM
Xenodrgn
Jun 13, 2002 11:52 AM
