Car lit on fire, what's salvageable?
Old Apr 5, 2023 | 06:36 PM
Walnut's Avatar
I did a TBI to carb swap on my 91 firebird 305. I guess my timing was off because it shot a nice fireball out of the carb and immediately lit everything in the engine bay on fire. Everything on the left side of the engine bay was on fire, everything on the right is fine still. After extinguishing the fire and looking at everything, the intake looks clean, carb still works, intake gaskets are a little melted, I'll need a new dizzy and plug wires and that's all easy. What I'm concerned about now is that the main wiring harness is melted and unusable. I don't have any power when I click the key to ON, the pop ups are up on their own, and the starter was turning while the fire was going, so something went horribly wrong in the harness. Can I rip out all of the engine bay wiring and wire straight to the alternator and dizzy, redo grounds and wiring to the starter? What all can I remove really is the question. I don't want to junk the car. I also already vacuumed up all the powder from the extinguisher.
Old Apr 5, 2023 | 06:46 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Re: Car lit on fire, what's salvageable?
Oh man that's tough. Check in with Painless or somebody else for the wiring.I carry a fire extinguisher with me. Good Luck!!!
Old Apr 5, 2023 | 07:51 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
There’s gotta be someone on here that can sell you a DS wire harness. Disconnect the burned one at the firewall (I think it’s the C100 connector) and install the new harness. Make a Wanted thread in the classified section
Old Apr 5, 2023 | 11:44 PM
Walnut's Avatar
So could I just remove the massive harness entirely and plug an older c100 from one of the Fbodies that had 2 separate harnesses or are the pinouts different?
Old Apr 5, 2023 | 11:57 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Im sure there's plenty of 91 tbi birds being parted that will have exactly the same parts you need
Old Apr 6, 2023 | 05:41 AM
battmann's Avatar
I don’t know which harnesses interchange. It would be best to find a replacement one that is from the same year as your car.
weesel72
Aug 27, 2013 06:08 AM
19f0rmula88
Nov 12, 2011 01:47 PM
ThUnDeR2005
Oct 19, 2006 04:43 PM
TBI305Camaro
May 21, 2002 10:30 AM
Demon Z28
Aug 14, 2001 12:39 AM
