Bad Engine Shake
Old May 22, 2024 | 08:40 PM
Blasted's Avatar
Bad Engine Shake
I replaced my harmonic balancer here recently (due to the previous one becoming a flying frisbee) and since then it has started shaking at low rpms. At idle the shakes are very minute, but at around 1200-1500 rpm the engine feels like a jackhammer was put in its place. The fuel gauge on the engine bounces between 5-7 psi, and it sounds like it has developed a misfire. I've replaced the spark plugs and the wires, and the problem still prevails. Was wondering if anyone has had any similar issues, or any tips on what to look for. TIA
Old May 22, 2024 | 09:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bad Engine Shake
Carb ? Tbi ?
Old May 23, 2024 | 05:40 AM
Blasted's Avatar
Carb ? Tbi ?
Edelbrock 4BBL (AVS2)
Old May 23, 2024 | 06:32 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Originally Posted by Blasted
I replaced my harmonic balancer here recently (due to the previous one becoming a flying frisbee) and since then it has started shaking at low rpms. TIA
Sounds like the wrong harmonic balancer.
Old May 23, 2024 | 09:03 AM
Vader's Avatar
Didn't we just have another one of those recently?
Oh, yeah:
https://www.thirdgen.org/forums/tech...r-humming.html
Old May 23, 2024 | 02:34 PM
Blasted's Avatar
What would be the right part number outside of Dorman? I can only find their parts when looking for the harmonic balancer
Old May 23, 2024 | 02:36 PM
Engine: Lb9
Transmission: M20
Look on RockAuto, summit or jegs. The balancer mark must match the pointer location.
Old May 23, 2024 | 02:38 PM
BBCSwap's Avatar
What engine do you have? Does the new balancer look IDENTICAL to the old one?
Old May 23, 2024 | 04:57 PM
Blasted's Avatar
It doesn't. The previous one had almost a "Channel" machined out of it going around the exterior. Its hard to explain, but I'll try to post photos tomorrow.
Old May 24, 2024 | 09:25 AM
Blasted's Avatar
Disregard. I have come to realize the engine is a 400 SBC and not a 305. Thank you all for the help and advice!
Old May 24, 2024 | 09:30 AM
Engine: Lb9
Transmission: M20
https://www.jegs.com/i/Proform/778/66513/10002/-1
I bought this recently for my 400 seems to be good quality
Old May 24, 2024 | 11:24 AM
BBCSwap's Avatar
Yep, the 400 takes a different HB then the others, it is externally balanced. It takes a different flex plate too.
orala
Nov 11, 2019 11:10 AM
jay173
Jun 5, 2010 03:08 AM
ughmas
Oct 25, 2008 10:01 PM
bigchief
Jul 24, 2006 03:25 AM
tommyboy51300
Jun 25, 2003 01:18 AM
