Need help. Long crank to start,fuel 20-25 PSI, F pump runs appropriate times.
Old Jul 2, 2025 | 11:38 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
1989 IROC Z 305TPI LB9 , AT. COMPLETLY STOCK.
Cranks over fine, takes very long to start, or no start. Stars FINE when I first squirt Carb Spray, into a fitting on the Intake Plenum and then crank over. Once it runs for a few minutes it starts PROPERLY. Problem only occurs after sitting about 8 hours, or so.
Key on engine OFF fuel PSI 20-25. Cranking PSI the same. Running PSI 33-37. System holds pressure OK. No change in fuel PSI reading when I pinch off the Fuel return hose, at the fuel rail. When I apply vacuum to the fuel pressure regulator vacuum fitting the fuel pressure lowers barely 1 pound.
Once it starts and runs for a few minutes, engine running fuel PSI is 36. AND then it starts UP PROPERLY.
A couple years ago I installed 8 new fuel injectors, overhauled the fuel pressure regulator, replaced all fuel rail O Rings, and installed a new fuel filter. I removed said filter and confirmed that is is NOT plugged or restricted.
The factory Specs say the Fuel pump is bad, because PSI is below 40.
I would hate to install new fuel pump (especially given the questionable quality they are) and still have the problem.
What say youse? Thanks, Mikeceli
Old Jul 3, 2025 | 10:12 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Need help. Long crank to start,fuel 20-25 PSI, F pump runs appropriate times.
Anyone?
Old Jul 3, 2025 | 10:29 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
What kind of voltage are you getting at the pump? It's either weak pump or crappy electrical. Hotwire kit and new pump fixes both.
Old Jul 3, 2025 | 11:13 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Change the pump. Check valve is probably bad. Happened in my 91 TA Vert and now my 94 TA Vert is doing the same thing.
I went with Delco/Delphi pumps, and did it (am going to do it,) the right way. Dropped/dropping the tanks. Not a bad job.....Even at 71 years old.
Old Jul 3, 2025 | 11:23 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
ya, it sort of sounds like you answered your own question. that pesky fuel pump. has it ever been replaced before? if not, then super highly suspicious, just like that girl you posted, looks AI generated to me!
EDIT: You have no ignition problem. Once fuel is in there, you have no problem. You confirmed nothing clogged. vapor lock? its a word i hear, but honestly dont really know exactly what it is
Old Jul 3, 2025 | 12:38 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Vapor lock is when your fuel starts boiling in the lines. Return style fuel systems largely eliminated the issue.
Old Jul 3, 2025 | 03:14 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
So the battery voltage drops to 10V cranking the engine. I'm installing a new one..."Just because". Was about 10V at the pump, cranking, also. Sounds like I am gonna order a pump. Delphi, because I do not want a noisy pump.
Old Jul 4, 2025 | 12:19 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I installed a new battery and ordered the Delphi FE0110 fuel pump. I decided on Delphi, because I do not want a loud pump, for me and the next owner.
Thanks, I will be back after the pump install.
Old Jul 4, 2025 | 01:24 PM
LiquidBlue's Avatar
Transmission: MD8
BTW - did you check your pressure relief valve located near the bottom of the gas tank. they are notorious for cracking. good idea on the battery.
Old Jul 4, 2025 | 01:45 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Would this be said valve? How do I check it? Thanks!
Old Jul 4, 2025 | 02:50 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I have used a couple Bosch pumps with good results. Nice and quiet, no problems for 50k miles so far on the Camaro.
Old Jul 4, 2025 | 03:27 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I telephoned Bosch, they said no listing for the 5.0 TPI, engine.
Old Jul 4, 2025 | 05:20 PM
LiquidBlue's Avatar
Transmission: MD8
yes, that is the valve. do a visual inspection and look for cracks. you can also take it off (but risk breaking it) and probably put finger on one end and blow on other or something like that. I think is sort of a check valve, if enought pressure builds in tank it will open. often people will smell gas in its area. they have exact duplicates at Hawks if you just want to replace it.
looks like your gas tank may have been off at some point in its life
Old Jul 5, 2025 | 01:23 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
What makes you say that?
THE FUEL TANK VENT VALVE has nothing to do with my 20PSI fuel pressure, correct?
Thanks.
Old Jul 5, 2025 | 10:49 AM
LiquidBlue's Avatar
Transmission: MD8
Thanks.
missing leather straps. all I know is it probably keeps the tank pressurized to some degree.
Old Jul 5, 2025 | 12:14 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
bETWEEN THE METAL STRAPS AND TANK? Good catch, I will make some.
Old Jul 5, 2025 | 01:06 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Old Jul 5, 2025 | 01:28 PM
LiquidBlue's Avatar
Transmission: MD8
yes, I dont know if it is rubber or leather, haven't been down there in a while. too busy building my new garage to play with my toys lately.
Old Jul 19, 2025 | 10:41 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
OP here...PROBLEM SOLVED.
I installed a new Delphi FE0110 Fuel Pump and Carter PD1 Fuel Pulsator. Fuel pressure is 40-42 PSI and the IROC Z Vert starts properly on command.
As always, Thank You All !
Old Jul 19, 2025 | 11:35 AM
LiquidBlue's Avatar
Transmission: MD8
Ooooo, thats a good feeling. Congrats!
Old Jul 19, 2025 | 11:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Great fix, I always chuck the pulsator. Don’t really get much noise transfer through the line
TPI Sierra
Sep 13, 2016 02:43 PM
godreject
Southern California Area
Sep 16, 2009 10:33 AM
jjlabinski
Sep 9, 2007 06:41 PM
joebeagle
Jul 6, 2007 04:17 PM
chevymec
Oct 23, 2005 06:08 PM
