#8 plug
Old Jan 24, 2002 | 07:56 PM
SgtSkip's Avatar
#8 plug
Is there a trick to replacing the #8 spark plug? I had a hard enough getting the wire to it. I'm cringing at the thought of changing the plug!
Old Jan 24, 2002 | 08:03 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Try to get it from under the car.
Old Jan 24, 2002 | 08:38 PM
poncho9789's Avatar
with a plug socket and a 3/4 wrench or short ratchet.
Old Jan 24, 2002 | 08:49 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
You're gonna have to raise the car and wiggle under there to get the #8 plug. You can access it immediately behind the a-arm (or whatever its called)....
Old Jan 24, 2002 | 08:56 PM
Yeah that #8 plug is a *****. You're gonna have to wiggle (or jack the car up in my case...) under the car and get at it from behind the a-arm (or whatever its called).
Old Jan 25, 2002 | 01:55 AM
PopaPork's Avatar
Well this might sounds STUPID but it worked for me. When I got my headers put on I couldnt get anything in to even get touch my #8. So what I did was take the socket wrench and bust off the the Porcelin of the plug, then I put the normal socket head on and took it right off. I know it is risky but if you dont smash it and break it off int he egine you are fine and this is a pretty damn easy way.
Old Jan 25, 2002 | 02:25 AM
Omar's Avatar
I have Edelbrock headers (switching soon to SLP, hopefully), and i found a very easy way. Take a spark plug wrench socket, go to a machine shop or wherever and have it shaved down to a length of 1 11/16". Using this, with a ratchet and 3/4 socket, I can change ALL my plugs in about 40 mins. My record was 30 mins. I can do all my plugs from the top, except #6 and #8, but even then, those are the EASIEST for me to do. Believe it or not, the passenger side is easier with this shaved down socket.
Old Jan 25, 2002 | 04:23 AM
poncho9789's Avatar
Me to that little slot (i did mine with a die grinder) has made changing my plugs so easy. It takes no time at all after you have had plenty of practice.
Old Jan 25, 2002 | 09:48 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
How about picking up a 200-185 Jet fan switch and swap it too while you're under there !
Old Jan 25, 2002 | 10:20 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
#7 and 8 are both pretty tough, but if you dont have A/C or smog its a little eaiser. I takes me all of 10 min. to change plugs, of course I've done it a few hundred times, and I can reach all of them from the top too, so that makes it quicker.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
