1992 Camaro RS 305 TBI – Stalling/Bogging Issue/ rough idle
Old Oct 4, 2025 | 02:31 PM
JLynn's Avatar
Hey everyone,
I’ve got a 1992 Chevy Camaro RS 25th Anniversary with the 305 small block and TBI fuel injection. Lately, it’s been giving me some trouble, and I’m hoping someone here might point me in the right direction.
Here are the symptoms:
• The car will sometimes stall when I’m coming to a stop or idling.
• A few times while driving, it stalled and I had to restart it.
• Occasionally, it bogs down like it’s struggling for fuel or air.
The idle will be ok then will start to go down really quick and low and jump back up fast and will keep doing it then when I rev it it will smooth out and then if you wait a little bit it will start doing it again.
Has anyone had similar issues with a TBI 305, or know what I should check first? Could it be something like the IAC valve, fuel pressure, or ignition-related? Any advice would be appreciated.
Thanks in advance!
Old Oct 4, 2025 | 02:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 Camaro RS 305 TBI – Stalling/Bogging Issue/ rough idle
Check engine light on ?
Old Oct 4, 2025 | 03:01 PM
JLynn's Avatar
Yes I think so
Old Oct 4, 2025 | 03:04 PM
Engine: Lb9
Transmission: M20
Originally Posted by JLynn
Yes I think so
and the stored code or codes are ?
Old Oct 4, 2025 | 03:13 PM
JLynn's Avatar
I didn’t know you could check codes on obd 1 port but when I get them I can tell y'all.
but it just started doing it wile driving I was told.
Old Oct 4, 2025 | 03:17 PM
Engine: Lb9
Transmission: M20
https://mechanicbase.com/trouble-code/obd1-codes/
Old Oct 4, 2025 | 09:09 PM
JLynn's Avatar
Thank you
Old Oct 6, 2025 | 05:14 PM
JLynn's Avatar
So I checked and when I started the car there is no check engine light it comes on when I first turn on the car then when I start it it turns off
Old Oct 6, 2025 | 05:18 PM
JLynn's Avatar
This is a video or sound of what it’s doing
Old Oct 6, 2025 | 05:43 PM
JLynn's Avatar
I just checked all the codes and the code 21 was on so I’m about to replace the throttle position sensor
Old Oct 6, 2025 | 06:07 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
I would check the voltage sweep on the TPS before changing it plus you probably would want to know what the TPS volts are at closed throttle.
Have you checked fuel pressure?
Old Oct 6, 2025 | 06:26 PM
JLynn's Avatar
No idk how there is no fuel rail
Old Oct 6, 2025 | 07:36 PM
JLynn's Avatar
And another question do you have to relearn the tps if so how.
Old Oct 6, 2025 | 07:38 PM
JLynn's Avatar
Thank y’all for all the help I appreciate it all to.
Old Oct 7, 2025 | 05:18 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Light comes on with key in "ON", engine off = Normal, bulb check
Light goes out when engine starts = Normal, means no active codes (no faults happening at this moment)
Found code 21 = That's in system memory (otherwise the light would be on now), which means it saw an issue in that system at one point in time. Note it's the system...could be it's adjustable, but out of range. Could be a corroded connection, a wire chewed by a mouse, etc. It does not instantly mean a bad sensor, though it could be that.
Agree with the above....knowing the voltage with the throttle closed, and at Wide Open Throttle (WOT) would be a start. Watching a volt meter as you move the throttle and watching for a smooth change in voltage with no big sudden jumps or dead spots would also be helpful.
starnes28
Nov 3, 2012 05:24 AM
3rdgenred
Sep 3, 2008 09:30 PM
rathack
Sep 26, 2003 01:57 AM
