Compressor question for a 305 l69
Old Feb 27, 2026 | 07:56 PM
Phantomwydd's Avatar
I have a 1985 trans am with a l69 engine. Putting a compressor in. And everything lines up with the compressor (water pump and crank shaft) but the only piece that doesn’t line up is the power steering pump. I tried finding a diagram but was unsure. Does my compressor belt also go around my power steering?
Old Feb 28, 2026 | 12:59 PM
Vader's Avatar
Re: Compressor question for a 305 l69
I am not certain on the L69, but the LB9 does route the A/C compressor belt around the P/S pump sheave as well.
The pre-1988 units had a confounding bracket arrangement for the steering pump, including a hidden nut, not-so-fun access to others, and a swing in a strange arc to tension the steering pump belt BEFORE installing and tensioning the A/C belt.
TheIgnitious
Jul 29, 2014 11:45 PM
88 TA GTA
May 28, 2012 12:18 AM
ThomasJ
Jan 18, 2011 02:10 PM
formula forever
Jun 4, 2007 09:20 PM
kanuck
Feb 4, 2003 02:47 PM
