Airbag Warning light
Old Feb 1, 2002 | 11:40 AM
Rogue Leader's Avatar
Car: a furry tractor
On My 91 Firebird since yesterday Sometimes when start it the INFL.REST. light stays Illuminated. Sometiems it doesnt. I just drove it this morning and it didnt. Should I be concerned. What or how do i check this, I dont want to blow the bag out. This car was in a frontal collision at one point in its life before i owned it and Its airbag did pop. And no i dont want to deactivate the airbag, I do believe in them especially after seing many many accidents in my time in the fire department.
BTW I recently replaced the coil and distributor because I got water in that area, so I know theres a sensor there could it being wet cause that? This is the first time it rained since I had that coil problem.
Old Feb 1, 2002 | 11:27 PM
anyone???
Old Feb 2, 2002 | 12:09 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Same problem
I have the same problem, mine stays on all the time. I tried to take the steering wheel off but couldn't do it cause the bolts stripped. now light stays on. Have you found an answer yet?
Old Feb 2, 2002 | 02:30 PM
No answer... now the light is off. BUT I doubt it to be a problem in the wheel itself, I believe its probably one of the 3 airbag sensors on the car (one in the nose and 2 on either side the firewall)...
Old Feb 4, 2002 | 04:07 PM
nobody knows???
Old Feb 9, 2002 | 04:16 PM
now it never shuts off... anyone????
Old Feb 10, 2002 | 04:06 AM
jester111's Avatar
hey
my two cents worth, the diagnostic modulator assembly constantly monitors the sir system. A malfunction causes the light to stay on continuously or to flash, and may possibly not come on atall. hope this helps
Old Feb 10, 2002 | 10:01 AM
The same ALDL as the SES light?? where is this located?
Old Feb 11, 2002 | 01:00 AM
jester111's Avatar
I was refering to the INFL.REST light but if your refering to the diagnostic modulator assembly then the answer would be no not the same as the ECM. It may be locatedin the center console or up in the dash however this is a guess. You may want to check a component locator for the exact location.
hope this helps
Old Feb 11, 2002 | 06:23 AM
cool i think i know where that is thanks!
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
