open air element
Old Feb 3, 2002 | 08:53 PM
Blade69's Avatar
open air element
will having an open air element give me horsepower????? instead of the air filter being closed up in the container.
Old Feb 3, 2002 | 09:48 PM
Guido's Avatar
Car: 2000 Trans Am
Moving to general engine forum.
Old Feb 3, 2002 | 09:52 PM
89BlueTA's Avatar
Yes, in my 85 TA, I gained a solid .2 in the 1/4 switching to a conical K&N filter. It was part of my free mods on my 89, it sounds a lot better also.
nick
Old Feb 4, 2002 | 08:18 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On a TPI car its not a good idea to run the open element on the throttl ebody, but to run it on the end of the induction hose where its away from heat, then purchase a heat shield to furthur sheield off the heat.
Thats how my setup is running now, with the supercharger.
-- Joe
Old Feb 4, 2002 | 12:36 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Will running an open element like on my TBI, lessen the chances of my car passing a smog test. Will it effect the results in any way?
Old Feb 4, 2002 | 06:12 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm sure you will pass a smog test just fine.
Try to use the edelbrock open element, it works good on tbi.
I ran one for a while one one of my older cars.
-- Joe
Old Feb 4, 2002 | 08:50 PM
Blade69's Avatar
what are "free mods"??????
Old Feb 4, 2002 | 09:20 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
"free mods" are mods that typically cost under 20 bux, and are purely labor..
Things like air filter changes, heat shields, throttle body bypasses, stuff like that.
Generally they help a little, but not all that much.
Old Feb 5, 2002 | 01:19 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
You will not pass the smog check in CA if you have an open element air cleaner. You will pass everything but the visual, I know this for a fact. If you get an open element just make sure that you keep your stock set-up and just do a quick swap when its time for testing, that is what I will be doing. It is worth the hassle and it is only a 10 min job if that.
Old Feb 5, 2002 | 03:32 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ermm. no.. Most open element cleaners with the PVC hooked, like the edelbrock one i recommended are 50 state legal and carry a carb EO number.
-- Joe
Old Feb 5, 2002 | 04:15 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
-- Joe
The heat riser on the stock exhaust manifold and the vaccum line from the TBI needs to be hooked up to the stock air cleaner, that is the reason that he will fail the visual part of the test.
Old Feb 5, 2002 | 08:26 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I figured they would that's why I asked. But like you said I'll just swap them out when the time comes. No Prob!!
Brinkkl2000
Aug 4, 2018 08:29 AM
Todd84Z
Sep 4, 2015 08:02 AM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
