What supplies to do I need to put my engine together?
Old Feb 7, 2002 | 11:38 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
OK guys, I've finally got all the machine work done to the block and heads, and I've collected all the parts I need to put the block together, and I've got the rings already on the pistons. I know I have to buy a piston ring compressor so I can install the pistons, and I need a harmonic ballancer installation tool (I may already have one), but what else do I need? What kind of lube do you guys reccomend for all the different spots? Do I use any special lube on the cam? The cam is a hydraulic roller, and I heard that you dont use cam lube on that type of cam? What type of lube do I need to use on the crank and on the rods? Thanks guys, I appreciate it! Oh, and just in case you need to know, the engine is a 406 SBC
Old Feb 7, 2002 | 12:44 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Redline Assembly Lube is great and it's ok for bearings,cam & lifters,etc.
Get or make an oil pump primer to use before startup.
ARP and others sell nice con rod bolt sleeves to keep from nicking the crank when you're installing the pistons/rods.
A degree wheel if you're planning on degreeing the cam.Biggest diameter you can afford.
-Rich-
Old Feb 7, 2002 | 01:04 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yeah, it was kinda fruity..
How about...
You need me, to go to your house, and we can put that bitch together and down a couple of 6 packs while doing it.
Better?
Old Feb 7, 2002 | 01:34 PM
rezinn's Avatar
Ewww... that sounded sort of fruity.
Old Feb 7, 2002 | 02:48 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Lol... :sillylol:
Old Feb 8, 2002 | 01:24 AM
Scott_92RS's Avatar
Car: 1992 RS
Originally posted by Sonar_un
You are going to need me, so we can go to your house, and put it together... together
Yea, that did sound kind of fruity. If you erase that last post, maybe you can come over
Old Feb 8, 2002 | 01:26 AM
Scott_92RS's Avatar
Car: 1992 RS
-Rich-
Thanks for the info, any tips for a smooth build process?
Old Feb 8, 2002 | 03:36 AM
Jza's Avatar
Jza
Instead of buying some sleeves for the connecting rod bolts, I just use some rubber hose cut to fit and slide them over the bolts. Other than that and what was already mentioned, a flywheel or crankshaft turning tool would be nice to have. And obviously, don't forget the torque wrench. Get a "seal saver" for the harmonic balancer. It's a little metal sleeve that slides over it. Helps out against leaks/wear in the long run. Take your time and don't "Ford" it (rushing to finish up and start the motor when you get excited near the end of the project).
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
