Heads
Old Feb 23, 2002 | 12:35 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Heads
What heads are the best for a 350? Within a reasonable price?
AFR,
sportsman II,
fastburns,
edelbrock,
etc etc
If and when I finally build the 350, I want to have something with good power.
450-500 sounds good
Thanks,
Chris
Old Feb 23, 2002 | 01:03 AM
Blackened's Avatar
For under a grand... Edelbrock RPM and TrickFlow 23 degree
For much over a grand... AFR 195s.
For $400 ... Vortec heads. But dont expect even near 400HP with them.
Old Feb 23, 2002 | 01:05 AM
iroc22's Avatar
Edelbrocks are a good quality head for the $$
Car: 92' RS
Engine: LO3
how mucg are the AFR's? I hear a lot about them but never got a price.
Also, whats the best power I could expect a SD TPI setup from a 350 to make? Properly tuned of course
Old Feb 23, 2002 | 01:17 AM
Blackened's Avatar
AFRs are about 1200-1300 I believe. More if you order certain drilling options, or different chamber volumes, etc etc
I had a 350 SD setup and I dont think I ever went over 300 HP. Went with a carb and made over 400 HP with just the carb change. I know it sounds bogus, but I did pickup over a second in the 1/4 mile.
Old Feb 23, 2002 | 01:20 AM
Car: 92' RS
Engine: LO3
Geez, just when I thought I was going to go with a TPI, maybe I will go carb, or maybe stick with my TBI
Old Feb 23, 2002 | 01:34 AM
Blackened's Avatar
Going carb will be a lot easier and if you want pure speed and acceleration... it's definetly the best induction setup. Edlebrock RPM heads, an Edelbrock RPM intake and 750cfm carb, and their RPM cam will make 420 HP on a garden variety 350. That's not bad! You willl run mid 12s easy with that setup. All for about 1500 ? Not too bad.
Old Feb 23, 2002 | 01:36 AM
Car: 92' RS
Engine: LO3
Do you happen to have stock in Edelbrock?
Just kidding, I like their stuff too.
Old Feb 23, 2002 | 01:52 AM
Blackened's Avatar
No I dont. A good friend of mine has a nice first gen Camaro with the whole edelbrock package on it. Heads, cam, intake and carb on a stock 350 bottom end. His car flies on motor alone clicking off low 12 second ETs. On NOS it's insane!
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
