Will these gears fit?
Old Feb 28, 2002 | 03:33 PM
BowtieFever's Avatar
Sorry guys.......my computer is all screwed up
Old Feb 28, 2002 | 03:35 PM
Lets try this again:
I have a 92 Camaro RS. It is the 10 bolt open rear with 2.73 gears. My friend has 3.23 gears from his 81 Camaro with a 10 bolt 7.5" rear. Could use these gears and the SLP torsen posi(3 series and 28 spline axles)? Do you think it would be worth it?
Old Feb 28, 2002 | 03:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's really a 7½" gear, then yes, it will work. I'd strongly suggest measuring the ring gear inner diameter to make sure though; IIRC the 2nd gen F car 10-bolt was a 8¼". The posi should fit his axles, and will acomodate that gear if it's the right diameter. IMHO it will be worth it if he's looking for a performance boost.
Old Feb 28, 2002 | 03:57 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
if i remember correctly, the 81 should have an 8.5 inch rear....
Old Feb 28, 2002 | 04:18 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Let's try this again!
92 Camaro has a 28 spline 7.5 diff
81 Camaro has a 28 spline 8.5 diff
8.5" rears use 2.73 and numerical higher gears on the same carrier.
7.5" rears use 3.23 and numerican higher gears on the same carrier.
in '89 7.5" diffs went to 28 splines
in '89 8.5" diffs went to 30 splines.
Basically your friends 3.23's are worthless to a third gen owner.
Old Mar 1, 2002 | 10:50 PM
Here is what he told me:
"I measured the gear and it is a 7.5 gear
here are the numbers you requested
pinion #'s 14035666-13-42-gm 83121n
ring gear #'s gm 14035665
13:42
42 Divide by 13= 3.23 ratio
the rear end may have been changed in the car before I purchased from the
previous owner."
Will they work now, what do you think? Thanks
Old Mar 2, 2002 | 12:03 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
I wouldn't say worthless! There's a lot of 2nd gen guys looking for those gears used and good shape. Those guys running 400 Pontiacs and 403 Olds engines are using those gears. That's what I'm running in my 77 T/A and they work real nice for a street car.
Old Mar 2, 2002 | 12:09 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
13:42
previous owner."
You can tell just by looking at the two. The 7.5s are tiny compared to the 8.5s. There wasn't any 7.5s from the factory in 2nd gens, totaly differant rearends. All 2nd gens had leaf springs in the rear, and NO torque arm, thank ***.
junkcltr
Aug 2, 2019 11:12 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
hectre13
Aug 26, 2015 08:17 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
