Got a 305 TBI that I am converting to carb..
Old Mar 18, 2002 | 04:27 PM
Camaro_hunter_d's Avatar
Ok I have a 91 305 TBI. I am converting it to carb. What else to I need besides intake, carb and distrib?
And No I do not live in EPA **** terriory.
Old Mar 18, 2002 | 04:32 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
You'll have to change the method of fuel delivery. Either get a mechanical fuel pump, or use a 3-port return style AFPR with your stock fuel pump. I opted for the later method.
Old Mar 18, 2002 | 04:33 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
So did I.
Old Mar 18, 2002 | 04:37 PM
ThirdGen Stoner's Avatar
If your removing the ECM, and your car is a automatic, youll need a TC lock-up switch.
Old Mar 18, 2002 | 06:02 PM
I forgot about that... Hmm ..
and yes I as thinking of a fuel block/regulator with return line and keep the 13 PSI Brand new in tank pump. (I know its new cause I put it in) I was thinking of having the PSI set to 9. Is that good or a little too igh?
Old Mar 18, 2002 | 08:16 PM
Anyone?...
Old Mar 18, 2002 | 08:57 PM
Mark305TBI's Avatar
Whatever carb you get will recommend a fuel pressure. Just stick a gauge in the line between the regulator and the carb and turn the little screw untill you get whatever they say to use. I think mine's about 7psi.
Old Mar 18, 2002 | 09:14 PM
joemo22's Avatar
Car: 1989 Camaro
Engine: 383
The fuel work is just one of the many "fun" things.
I have switched from tbi to carb and i love the results.
I mounted a holley fuel pump right by the wheel well. (drivers side)
The fuel lines run almost perfect. You will need some rubber hoses. A way for the throttle to reach the carb. I cut it and welded it forward a few inches. Then you have to worry about the kickdown. Basically its a lot of riggen **** up.
Please if you remove the manifold dont forget to drain the anti freeze. I have heard stories where people say it won't harm the engine.
Another note:
You need to drop the fuel tank, remove the old pump and add a piece of copper in place and hmmm... make it flare out at the end a friend of mine did it i think he used a washer.
Old Mar 18, 2002 | 11:32 PM
damn double post...
Old Mar 18, 2002 | 11:34 PM
Another note:
Acyually I plan on keeping the elec pump in the tank. I just replaced it when I bought the damn car. Its only a 14 PSI pump and I can run a fuel block with regulator and a return line...
I will rig the fuel line to the carb.. no biggie there.
Thanks for pointing out the throttle cable may need "adjusting", I have a welder so again no biggie...
And yes I pan on draining all fluids actually cause... well... it needs it anyway.
The kick down will take some real thought though.... hmmm a few spot welds, a few welded on plates and all should be fine...
I decided to swap for 1 the TBI cars SUCK for power(and I have heard by many people that a 625CFM swap adds a few good poines!). My V6 beats them easily(when they have a few not alot of mods) 2 I am sick of the starting problem. The damn thing refuses to start unless you spray it with starting fluid...
What if I don't hook the kick down up, or hook it up like a T350 I don't plan on racing the thing by any means anyway. I plan on shifting manually anyway... And I do have a rebuild in store before the swap. hell maybe i should just get a TH350... alot less to deal with...
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
