Will I need new springs with this cam?
Old Mar 18, 2002 | 06:07 PM
Chris85TA's Avatar
cam specs are: 214/224 duration at .050
.442/.465 lift
I have stock springs now. The motor is a 350 and I'm gonna put some 882 heads on it.
Old Mar 18, 2002 | 06:13 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
If you going to change your cam you should put on aftermarket springs. Because the last thing you want is for the valves to float and ruin your engine.
I have a 1988 Iroc-Z, with the 350 tpi in it. I plan to race it and will be changing my springs soon, because over time your springs will get a little weaker and theirs a chance that the valve will float.
Old Mar 18, 2002 | 11:21 PM
jeffs82z28's Avatar
The cam specs sound like the performer rpm from edelbrock. I would install the edelbrock springs if it were my motor
Old Mar 19, 2002 | 01:33 AM
Blackened's Avatar
That's not even CLOSE to the specs for an edelbrock RPM cam... It would have to be 230/240 duration at 0.050 and more lift.
For the cam the stock springs should be fine. I know they work fine up to .490 lift. I wouldn't worry about it.
Old Mar 19, 2002 | 04:31 AM
ede's Avatar
ede
isn't even a question, change springs when you change cams as well as go to aftermarket retainers and get rid of the factory rotaters
Old Mar 19, 2002 | 10:01 AM
jeffs82z28's Avatar
OOPS, I guess I had more to drink last night than I thought I had
Anyway, Yes put in the springs recommended by the cam manufacturer, that way you will have proper spring pressure for that cam grind and material.
Old Mar 19, 2002 | 10:27 AM
Vader's Avatar
Stock valve springs aren't even truly adequate to control the stock valve train at elevated RPMs - like anything near the yellow-line. The situation is even worse with heavy, unnecessary components, like the exhaust valve rotators that Ede is talking about.
Stock springs will handle quite a bit of lift without binding, but also generate a lot of heat at elevated lifts (no pun intended) and don't have adequate pressure to keep the lifter on the lobe at higher RPMs. Even a slight bit of valve float may not cause valve/piston interference but can ruin valve train compliance and cost power at higher RPMs. As someone once put it - "Once the valves start to float, the party's over."
Of course, you are installing screwed rocker studs while you're at it, right?
Old Mar 19, 2002 | 10:49 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The stock springs will work with the cam you stated if they are
still within spec. Pressure should be 70# or more @1.7" installed height. Stock diameter replacement highperformance valve springs are not expensive I'd use K-motion K700's for this application. You can reuse the stock retainers and oil shields.
There are lots of better heads than those 882's. Performance will be only modest at best with them.
Old Mar 19, 2002 | 04:33 PM
Chris85TA's Avatar
I got the 882's for free. The heads on it now are small valve heads. For $40 I'll get some edelbrock springs. These used springs have unknown mileage.
Old Mar 19, 2002 | 10:53 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Those 882s are smog heads! Your engine would most likely run better with your stock heads. What are you installing them on? They're most likely 76cc, = drop in compression.
Old Mar 19, 2002 | 10:59 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
since you have the heads already off i recomend a set of edelbrock torquer springs.
Old Mar 20, 2002 | 04:10 PM
Chris85TA's Avatar
The heads I have now are junk 76cc small valve castings. The 882's outflow L98's and have 1.94/1.50 valves.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
