car smokes...
Old Apr 1, 2002 | 11:13 PM
Toms88am's Avatar
car smokes...
upon starting, i notice a little puff of blue smoke. It goes away while driving. After car sits and and then started the puff returns.
I'ts not consuming more than usual amount of oil, maybe a half qt or so every few weeks the engine has good power throughout the rpms. block has 130k miles, heads are new <8k miles. could it be a valve guide or seal? or just bad rings? or is it just time for a 383 stroker?
Old Apr 1, 2002 | 11:21 PM
rezinn's Avatar
You're probably right about the seals/guides, although they are fairly new. Are they actually new, or just new to the car? Did they sit for a decent amount of time? The seals can crack if left out or unoiled.
Anyhow, while the car sits the oil that was above the seal leaks down. Oil could not leak up through the rings, it can only be pushed up through them (when they are bad) when the engine is in use, and typically at higher rpms.
Old Apr 1, 2002 | 11:51 PM
Toms88am's Avatar
yeah... thats what i figured (I think someone forgot a seal). I'll have remove the valve covers and inspect...the motor just runs too-good to have bad rings, though i do notice an oil smell from the exaust during long idle periods. (sitting at a long light)
Old Apr 2, 2002 | 07:17 AM
82camaro's Avatar
Car: 82 camaro SC
1/2 a quart every few weeks--how many miles is that. Usually the problem is the valve seals/guides. However, if you have a stuck/broken/worn oil control ring it will still use oil but run pretty good.
Old Apr 2, 2002 | 10:58 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
You know whats wierd, my car will puff a little blue smoke upon startup (moreso if its warmer) and will kick a little out at high rpms. Its blue and looks like its burning oil, but the funny thing is that my oil level never gets low. I check it all the time and amaze myself, i guess its burning a little but not enough to make me low. Wierd. Also, since i dont have a catalytic converter could that make a difference in the amount of smoke? I was thinking since i dont have a cat, that i puff more smoke then if i would have one. Any correlation?
Old Apr 2, 2002 | 08:22 PM
Greg Kuhlmann's Avatar
3 words for you CHEVY SMALL BLOCK
dont they all pretty much smoke with around 80k???
Old Apr 2, 2002 | 08:32 PM
rezinn's Avatar
Yeah.
Old Apr 2, 2002 | 09:16 PM
SoCo80p's Avatar
yep the world famous 3rd gen valve guide leak
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
