4.3 v6 and 350 L98 v8 parts swapping
Old Apr 6, 2002 | 07:37 PM
Pupil's Avatar
will the ac /ps and alternater brakets and pullys off of an 4.3 v6 work on my v8 350 l98?
Old Apr 6, 2002 | 07:41 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
They should.
I used all the brackets off my 4.3 on my 350.
Old Apr 7, 2002 | 01:12 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
350 L98 V8? gee, anymore information about it you want to list? maybe cc or anything? as for your brackets, they should work with no problems.
Old Apr 8, 2002 | 01:17 AM
Ovrclck350's Avatar
I don't blame him for listing it. L98 lets us know that it's TPI.
Old Apr 8, 2002 | 01:45 AM
Vader's Avatar
IIRC, the accesory "brackets" on a 262 V-6 are for the most part one single stamping that covers most of the front of the engine. Yeah, it, or "they" should work.
Old Apr 10, 2002 | 08:29 AM
Pupil's Avatar
well its a L98 all stock except for water pump in take and oil pan and tbi and its not tPI its a TBI motor
Old Apr 10, 2002 | 09:39 AM
Vader's Avatar
Pupil,
If it is a stock 350 in a ThirdGen, then it's an L98. The "L98" RPO designation is for a 350 TPI engine. If it is truly a TBI, then it is either a L03 (305) or a replacement engine from a different vehicle. Several full sized GM cars and trucke were equipped with a 350 TBI, but not 'F' or 'Y' cars.
Regardless, the brackets should bolt up and work.
Old Apr 10, 2002 | 12:50 PM
Pupil's Avatar
I probably wrote in error but the whol tbi system is after market holley tbi and edlebrock manifold but the car it came out of was a camaro and it has 5.7 stamped on the block I checked the cast numbers and it says 90-92 f-body so maby the previous owner swapped every thing out for the tbi?
iloveacamaro
Sep 20, 2017 08:39 PM
ShiftyCapone
Dec 3, 2016 11:30 PM
Juggernaut
Jan 17, 2003 07:34 PM
Drew
Sep 11, 2001 10:28 AM
