92 Z28, the govern speed?
Old Apr 10, 2002 | 01:09 AM
msclmn0079's Avatar
Im not sure what its called, i believe a govern or governer or something like that, that wont let you go past a certain speed. does anyone no what the limit is for a 92 z28 with a 350 TPI? and is there a way to get rid of the govern thing? and does it cost alot to take in and have it taken out or is it something you can do on your own?
Old Apr 10, 2002 | 01:14 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Don't worry about it.....
Only 305 TBI cars had a governor (something 110-115 mph).....
Old Apr 10, 2002 | 01:17 AM
TBIWorks's Avatar
Well the 350 and 305 TPI's didn't except......!!! The 305 TPI convertables with the automatic tranny and the 110mph speedo had a governor guys,
Old Apr 10, 2002 | 06:51 AM
blk91z28's Avatar
i have a 91 Z28 convertable 305 auto with a 110 speedo and mine doesnt have a governor.
Old Apr 10, 2002 | 11:49 PM
Vader's Avatar
All ThirdGens have a programmed fuel injector pulse cutoff at a given VSS speed. Cars that were not equipped with 'Z' rated tires had the fuel cutoff somewhere around 118 MPH, but that may vary slightly across the years. Since the ECM calibration requires SOMETHING in that data field, cars that were equipped with 'Z' tires were programmed at 255 MPH. This is the maximum value that can be programmed in 8-bit binary format, or the CPU's operating language. (And before all the tuners get involved, I understand that the ROMs are written in hexadecimal to conserve address space, but the CPU can only switch ones and zeroes - AND, NAND, OR, and NOR gates don't like anything else.)
So in essence, all cars have the fuel cutoff programming, but some just have an almost impossibly high speed number, so they are virtually non-governed.
Old Apr 11, 2002 | 07:12 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My 92 Z28 convt (stock) has a limiter. 110mph she drops a bank of injectors.
Old Apr 11, 2002 | 08:29 AM
TBIWorks's Avatar
like I said the Z converts (with automatic)had the governor because they came with H rated tires. Also, the speeds did differ, my '92 Camaro suts off at 112, and my buddy's 92 Bird shuts off at 120. Mine is an auto, his is a 5-speed. Maybe the Z-28's with a convert and 5-speed(if they made them?) had a higher governor, but I'd suspect it is between 110-120mph unless the car came with the Z-rated tires of course. Even the LT1 cars with the 110mph and convert were governed at 110.
Old Apr 11, 2002 | 10:47 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Alright....I have an 88 Iroc with a 305 TPI and the T-5 with T-Tops and mine has a governor at 3,000 RPMs. I used to have the stock 3.08 posi rear in it and i could get up to about 120 and now with my new rear i can get up to about 115. Its a 3.45. How would you take it off
Old Apr 11, 2002 | 10:56 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
programming removes it. as for the car in question, all 5.7 cars were equipped with the z rated tires on third gens so it shouldn't have a speed limiter.
deracer
Apr 11, 2016 12:04 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
19irocz85
Aug 26, 2015 07:54 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
novaderrik
Aug 10, 2015 12:44 PM
