Replacing the O-2 sensor........
Old Apr 11, 2002 | 09:12 PM
War_Eagle's Avatar
I have an 86 T/A with the 305 and I'm getting ready to attempt to change the oxygen sensor. Is this a tough job? Any first hand experience out there? Any hidden problems that I should be looking for? I'll take all the help I can get, Thanks.........
Old Apr 11, 2002 | 09:21 PM
PonchoTA's Avatar
Only thing easier is replacing the air filter.
Best to get the proper cut-away socket with a long extension and a u-joint or 2. Can be done from above.
Good luck!
Old Apr 11, 2002 | 09:25 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Good luck trying to break it loose it will take a good bit of WD-40 and when you try to install the new on clean the threads up good and use that spcial grease that comes with it, and also dont overtorqu it or you will get a s&*$^*y running car.
Old Apr 11, 2002 | 10:03 PM
bustatc's Avatar
Its an easy job.
Old Apr 11, 2002 | 10:05 PM
RICHRAD's Avatar
Removed mine the other day on my 86T/A. Amazingly simple, I was stunned after all I had read before. Forget about wd40, takes too many applications. Get yourself some Marvel Mystery Oil penetrating spray at Wal-mart. Give it one good shot of that stuff and a few minutes to soak. If the six point pattern of the o2 is turned just right you can get an open end wrench on there( one that fits snugly) and break it free. I have been tearing my motor and engine compartment down with this spray and it never fails .WOW!!
Old Apr 18, 2002 | 02:29 PM
85NJTA's Avatar
hey all, i was gonna ask the same question, its time to change my o2 sensor, but i quess its pretty easy. Will changing it/not changing it effect if i pass inspection( i just bought the car and finally got it registered).
ok one last question, i am getting a code 34, high vaccum from my maf sensor, is this hard to fix?
Old Apr 19, 2002 | 06:55 AM
camaro6spd's Avatar
WD-40 is not a very good penitrating oil......this summer i dicoved PB blaster.....that is some GOOD ****, I sprayed on top of a bolt that had a recession around it and filled that recession with the oil.....in about 10 min it had worked it way down and around the bolt to the other side, which was about an inch or so....it was an exhaust part, so it was rusted up pretty good....Nut came off with out too much effort, i replaced it with a brass one tho. Ne way...PB Blaster, white spary can and a Yellow Cap.....GREAT ****, Wal-Mart.
Old Oct 4, 2002 | 06:40 PM
sub's Avatar
sub
... where I live they shut down emissions for awhile to change the system or somesuch ... don't need a vehicle inspection until my car is 25 years old either ... finally getting insurance on my car by the end of next week, woo .... I'm having an issue with Code 34 as well. I disconnected my MAF sensor and my car still runs like crap, seems ok if I'm pushing it, but it's not a very nice idle. It almost dies out and then revs back up to life :sigh: I'm going "shopping" tomorrow too ... just gonna look around the local junkyards for some of my cars ('87 Camaro 2.8L, '89 Beretta 2.8L, and an '85 Buick Skylark ) Skylark has carb-linkage issues ... and I'm not buying a new carb for it ... I'm trying to sell it anyways :\
So has anyone found any places where vacuum leaks occur more commonly than others? Any help would be appreciated
Old Oct 5, 2002 | 12:25 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
One more thing to keep in mind.....
Don't touch the tip of the O2 sensor. There's a plastic cap over it for a reason. It's like a halogen bulb. The oil on your skin can contaminate the tip and it will take some time for the ill effects to wear off.
AJ
Old Oct 5, 2002 | 08:17 AM
sub's Avatar
sub
Sorry, I'm new to all of this .... What's this sensor for?
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
