Need help with cam install.
Old Apr 12, 2002 | 08:23 PM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Ok now the problems start I got the cam in and lined the dot up with the zero and now the motor wont turn all the way around its like the cam is running into something. Any Ideas? this really sux. I took it back apart and turned #1 to TDC and reinstalled it so the cam sprocket dot was straight up and turned it and it ran into something again. Im all out of ideas. All the lifters are out so its not like im hitting the valves. What do i do?
Old Apr 12, 2002 | 08:37 PM
Stroked-Z's Avatar
Specs on the cam?
Specs on your piston & deck height?
Specs on your timing chain (true roller w/ adjustable sprocket?)
I've seen people line up the "o" on 3-way adjustable sprockets.....there are 2 litlle "o" marks.....1 for timing retard & other for Straight Up.....
Give us some more details.
Old Apr 12, 2002 | 09:20 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Welcome to the world of running a cam that has too much lift with a motor that has a long stroke. I can just about guarantee (depending on cam lift) that the edges of your rods by the rod bolts are hitting the cam. Solution? Use a smaller lift cam or do the real thing - order a small base circle cam. Sad but true.
Tim
Old Apr 13, 2002 | 12:03 AM
383GTABoy's Avatar
Engine: 383 4 bolt
heres my specs
* Advertised duration: 268 intake/280 exhaust
* Duration at .050 in. cam lift: 224 intake/230 exhaust
* Gross valve lift: .479 in. intake/.480 in. exhaust
* Lobe separation: 114 degrees
* RPM range: 1,800 to 5,800
I thought the lift was still kind of conservative. Do ya think i could advance or retard it abit to miss the bolts if that is infact what it is. Hmm small base circle cam where would you go to get one of them that is similar to the lt4 specs
Old Apr 13, 2002 | 03:11 PM
boogie's Avatar
Sounds to me like your rods are hitting the cam, this will happen with 5.7 and 6.0 length rods in stroker motors. You will have to clearance the rods or run a small base circle cam.
Lonnie
Old Apr 13, 2002 | 07:02 PM
ORAY777's Avatar
Round off just the out side bolts that contact the cam just enough so it will clear. I seen this done on TV/ or in a magazine.
Old Apr 13, 2002 | 07:04 PM
ORAY777's Avatar
If the rods are hitting the bottom of the cylinder bore then you have to clear the bottom edge of the bores just enough to clear the rods.
Old Apr 14, 2002 | 12:02 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i lined my cam gear dot to the crank gear dot that's above the keyway instead of the dot that's three teeth in the counter clockwise direction from the keyway dot. this resulted in my valves hitting the pistons. i'd check to make sure you've got the right dots but that shouldn't cause problems without lifters in there so it's probably your long stroke causing problems.
Old Apr 14, 2002 | 12:09 AM
383GTABoy's Avatar
Engine: 383 4 bolt
Im going to wait untill monday and have my builder come take a look and if worst comes to worst guess it time for a small base cam
Old Apr 15, 2002 | 03:00 PM
383GTABoy's Avatar
Engine: 383 4 bolt
Thanx for all of your help guys. I ordered my small base circle cam today. special grind was only $188 not bad huh. all i changed was my lobe seperation to 112 hopefully the new cam will work well. Ill post again when i get it in to let you guys know how it goes
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:40 AM
masonta
Sep 1, 2015 06:40 PM
