What's up with this line lock?
Old Apr 12, 2002 | 11:29 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I installed a line lock today and it isn't working. There is only two wires. Pos. and Neg. I wired the the switch up correctly and got a friend to test it out while I listened for the solenoid to engage. I could just barely hear a click and it wouldn't hold the brakes. We tried and tried but no luck.
Oh, it's a TCI that came from Jegs. Are these just junk? I got frustrated and just unhooked it.
Old Apr 13, 2002 | 09:50 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
ttt
Old Apr 13, 2002 | 11:21 AM
BlackBird305's Avatar
yea anyone have any experience with this?...i just got mine in the mail and now im starting to worry after reading the previous post...thanks guys
Old Apr 13, 2002 | 11:38 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
"blackbird305" Is yours a TCI?
Old Apr 13, 2002 | 01:42 PM
yes it is..."TCI Roll-Stop Kit"...jegs p/n 890-861700....when u hooked it up did u use a double or single flare when connecting the solenoid to the brake line?
Old Apr 13, 2002 | 02:07 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I went to Advance auto parts with the line lock and just got some fittings that looked like they would work. The one that I used on the master side looks just like the one that came out of the master cylinder. I'm not sure if that is flare or reverse flare. I think reverse flare.
On the other end I used one that looks like a pipe bushing. It's 1/8" pipe thread to female flare fitting. Again, I can't tell you which is which when it comes to flares. I was thinking that flare is when it's sort of the female side and reverse is the male side. I just don't know.
At any rate, I got it to hold fluid and not leak. That was my main concern. Now my main concern is getting this thing to work.
Old Apr 14, 2002 | 08:21 AM
bhaas's Avatar
Are you "working" it right? Do you push the breaks then push the button on the switch then let off the brakes and it should hold the front tires? Do you have the front brake line going to it and not the back? Just thought I'd ask.
Brad...
Old Apr 14, 2002 | 08:54 AM
DABE's Avatar
heres a tip...i have TCI line lock....you have to hit the brakes...get pressure up...then hold the switch then let off the pedal...then its ingauged....it runs off of the pressure that is running through the lines...just a tip....try it and get back....if you want ill take pics of my setup....so you can see how its installed....
DABE
Old Apr 14, 2002 | 01:03 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Well, I have pumped the brakes really hard and then pushed thes brake pedal in as hard as I could with two feet. Still no luck with it working. I really think that the solenoid isn't working. When I got my buddy to push the button I could just barely here a click. Most solenoids that I have heard make a loud click.
I do have it hooked up correctly on the front and not the back. I know that I am working it correctly.
Dabe, I would really appreciate it if you could take some pics of yours. I'm pretty sure I did it right but I would like to compare.
Thanks for all the replies.
Old Apr 14, 2002 | 10:08 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
ttt.
Old Apr 14, 2002 | 10:37 PM
Omar's Avatar
How is everything setup? Did you setup the line lock before or after the proportioning valve? Any leaks? Is the car braking ok without the activation of the line lock?
Old Apr 14, 2002 | 10:45 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
No leaks. The car brakes just fine without it engaged. I ended up just unhooking the wires and saying forget it for now. I think that I am calling Jegs tomorrow to see if maybe they will exchange it. It doesn't sound like it is engaging correctly.
By the way, I still would like to see the pics.
Old Apr 15, 2002 | 02:32 PM
DABE's Avatar
ok...ill get them sometime this week...dad is out of town and he has the camera....later
DABE
Old Apr 15, 2002 | 08:31 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
ok, thanks Dabe.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
