How high can you safely rev a stock L98?
Old Apr 14, 2002 | 05:31 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Just wondering (i know the tach says 5500)?
Old Apr 14, 2002 | 08:24 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
There no point in revving past 4500 rpms, but if you are wondering for future reference for mods, I'm not sure.
Old Apr 14, 2002 | 08:27 AM
Jester's Avatar
Like he said, there is no point in taking an L98 past 4500. it can;t breathe any higher.
If you're asking about the stregth of the bottom end, then I'd put the limit at about 6000, maybe 6500 tops if you don't mind being a a little risky.
Old Apr 14, 2002 | 10:29 AM
GreenProStreet's Avatar
Port the heads, change the cam, and balance the crankshaft and they make good power untill 6 grand.
Old Apr 14, 2002 | 10:44 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Through a lot of testing, I have 5,000 rpm to be my optimum shift point. Yeah the engine will rev higher, but you end up going slower in the 1/4 due to the TPI intake choking the air flow.
Old Apr 14, 2002 | 10:57 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it should hold together up to 6500 for short bursts, but it is pretty much worthless above 5500 and stops pulling hard above 5k.
Old Apr 14, 2002 | 05:39 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I was kinda wondering the same thing. I know that it won't breathe past 5000 or so, but i was wondering myself at what rpm its safe to take it too. I know that on some cars the redline is set by power production, accesory speed, or valve float issues. I was jsut wondering, if i got a freer flowing intake, how high could the valve train/ acessories/ rotating/reciprocating internals go?
Old Apr 14, 2002 | 06:05 PM
Hellraiser's Avatar
I can't say it will happen to everyone, but i've had problems with blowing the clips out of the lifters above 5k on stock 350 motors. It's happened to me twice while doing high rpm burnouts. =)
Old Apr 14, 2002 | 08:46 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
hmm thats wierd, we used the hydrolics in the stock car, spunt hat thing to 6800 all the time... we did eventually switch to solids tho, but for a diff reason.
Steve
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
TheExaminer
Aug 19, 2015 10:07 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
