Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
90 IROC AUTO, where to shift at?
Old Dec 7, 2004 | 10:21 PM
CamDragonZ28's Avatar
Car: 1990 Camaro IROC-Z
I've read a few different comments for other cars and there shift limits, but they were all manuals. How does it differ for an Auto.
I have a 90 IROC-Z 350TPI all stock cept for 8.5mm Superconductors and Cat-back exhaust into 4" pipes to 4" Flowmaster. I Took her to Los Angeles County Raceway and ran a best 14.785 @ 92mph on street tires. I was shifting 500 before redline, but I've never really known as far as using the stock auto-tranny, and having that shift lag what the best shift rpm was. thoughts?
Old Dec 7, 2004 | 10:26 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Well you make pead HP at 4400rpm....Try shifting at around 4600-4800rpm.
Experiment, see what makes the best time.
Old Dec 7, 2004 | 10:28 PM
/\/3\/\/l8l3's Avatar
Old Dec 7, 2004 | 11:02 PM
nidyanazo's Avatar
After 4400rpm he is losing power....Why would you recomend 1000rpm after peak hp?
Old Dec 8, 2004 | 12:44 AM
stu
Guest
Posts: n/a
Maybe the extra time he loses not making power past that point is made up by falling into the next gear at a much higher point in the power band.
Old Dec 8, 2004 | 01:01 AM
nidyanazo's Avatar
When my car was stock I tried different shift patterns, my max hp came on at 4000rpm. Stock, when left in drive the auto trans would shift at 4500rpm at WOT. I tried shifting manually up untill 5200. Past 4400 there is a noticeable decline of power. Like I said, try different shift patterns untill you find the one that yeilds the best e.t. Use that pattern.
Old Dec 8, 2004 | 01:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i picked up about 2 tenths by shifting at 4700rpms over the 4300rpm shift point with the auto doing it.
thats the only reason i would shift it. if the auto doesnt shift at atleast 4400-4500rpms by itself then manually do it at 4600rpms. should be happy with that.
remember 700r4 has 3.06 first gear and 1.6 second i think. thats alot of gear drop so try winding out first to 5000rpms and shift
hold 2nd till 4600rpms.
nidyanazo's Avatar
I do see what you are saying though Stu, and it makes sense. The autos are kinda slow-shifting. Untill you get a shift kit, use B&M "trick shift" fluid. It seems to firm up the shifting action slightly. I like it.
I did notice however that if I shifted at 5000rpm (that's 1000rpm over my max hp) That I would feel a bigger "jump" into the next gear. But the time it takes to spool up 500rpm may or may not be worth the extra "jump".
Experiment!
Old Dec 8, 2004 | 01:14 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
trick shift sucks get lucas or redline
Old Dec 8, 2004 | 02:57 AM
nidyanazo's Avatar
Works for me. back at 'cha
Old Dec 8, 2004 | 01:56 PM
Thanks guys. Ill definately try both and see which works better. I wasn't aware that the powerband for the trans was so low. we'll see if I can get better times between shifting lower vs the high shifts at about 5200rpms I was making.
Old Dec 8, 2004 | 02:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heres a HUGE tip..
if you're using the stock tach, go into the redline.
why?
because the tach is totally inaccurate and reads low.
so while you THINK you're shifting at redline, you're realy short shifting that..
that ALONE made over 7 tenths of a diff for me.
Old Dec 8, 2004 | 02:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
are you sure mr dude?
most are only off by alittle. you better check first before you do go to redline. LOL thats a way off tach. mine idles at 600-700rpms when warmed up and i do about 55 mph when in third gear rolling at close to 2000rpms. I forget my exact numbers but i calculated it slightly off 200-300rpms. i think it was too low, so i go to shift at 4700-4800rpms. but it feels strong till 5000rpms so maybe....
Old Dec 8, 2004 | 03:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
positive. 99% of them are off... lol.
2 quicky ways to check it:
1. use a laptop and ALDL cable
2. use a aftermarket tach.
the third way is to note the RPMs and speed and do the math
but with the speedo inaccuracy, tire size diffs, cable diffs and/or mechanical->digital->mechanical changes, its just not accurate enough to tell if you're off.
Old Dec 8, 2004 | 03:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
next trips to the track will be with my 3.27 gears and firmer adjusted shift kit, so i will try shifting at different points. i probly will get 4 runs or so. i will try 4500rpms, 4700rpms, 5000rpms and maybe 5200rpms. whenever spring time comes, i will see how it goes and get some numbers. LOL
Old Dec 8, 2004 | 03:31 PM
/nod
Old Dec 8, 2004 | 07:09 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
I dont know about you guys but my new 700R4 without a shift kit shifts at 6300 RPMs all by itself. I also have 3:42 gears ... mods are in sig.
Old Dec 8, 2004 | 07:45 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I read that one of the mags(I don't remember)got its best results shifting the auto at 5400. I personally don't even shift my car. I have a transgo kit and it does just fine by its self. I shift and lose time or get about the same times, but thats just me.
Old Dec 9, 2004 | 02:18 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
totally check your factory tach.. i didnt relize how far mine was off unitil i got to the track and hooked up to data log with my friends pc and cable.. odds are your is to. as far your shifting, i woudl get a good torque convertor and leave it in drive. thats how i been abel to get teh most ET out fo my car.
jklein337
Sep 19, 2018 06:23 PM
g.l.mos
Aug 22, 2015 12:02 AM
dhonda200
Aug 11, 2015 11:50 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
