remember what you guys said my 305 4bbl swap would run hehehe
Car: 1991 Camaro RS
Engine: 4 bbl 305
well guys i hate to do this but i once again have proved there aint nothin wrong with a good ole 305 heres the new updated ET
R/T-.523
60'-1.926
330-5.732
1/8-8.889
MPH-77.72
1000-11.649
1/4-13.994
MPH-96.87
how do ya like them apples
old 305 4bbl "GOT R DONE"
R/T-.523
60'-1.926
330-5.732
1/8-8.889
MPH-77.72
1000-11.649
1/4-13.994
MPH-96.87
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: remember what you guys said my 305 4bbl swap would run hehehe
R/T-.523
60'-1.926
330-5.732
1/8-8.889
MPH-77.72
1000-11.649
1/4-13.994
MPH-96.87
R/T-.523
60'-1.926
330-5.732
1/8-8.889
MPH-77.72
1000-11.649
1/4-13.994
MPH-96.87
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
thats alot of stall
what gears in the back ?
oh, and what are you planning next ?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by Dennis91RS...i once again have proved there aint nothin wrong with a good ole 305.
j/k! Have you considered a single plane/650-cfm set up? Trending Topics
Car: 1991 Camaro RS
Engine: 4 bbl 305
i thought about getting the S/R World Product heads for the 305 and going up to a 650 holley
the rear has 3.42 with an auburn pro series posi trac
i dont think there is an all motor 305 running in the 12s yet is it??
i figure with the head swap and the three piece pulley set and 650 it should turn a 13.40??
the mods now pushed it barely into the 13s but i figure if i do the head swap then i could put a chigger bigger cam in it too so maybe, just maybe i can put the ole 305 into the 12s at 100+ mph
wouldnt that be some shiznik
Originally posted by Dennis91RS.i dont think there is an all motor 305 running in the 12s yet is it??
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
not bad for a 305!
hopefully mine will be there shortly... since im selling my GN, alls i have left to play with is my old LG4 Z28. 14s shouldnt be too far away for me
one thing i would change on your setup is those flowtech headers. 1.5" primaries are probably too small for the power youll be producing with the new heads. id at least step up to something like 1 5/8" hedman LTs or something
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by johnjm22
Do you think you could have done that if you were still running a TBI?
Great numbers!
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Seems like a lot of work and effort to crack a high 13. Should have gone with a 5.0 Mustang, bolted on some gears, and ET Streets and gone 13.9s!
Very nice times for the little 305. We had one at our track a while back, running low 14s. The only thing was the car was a race car. Big slicks, no exhaust, gutted, all out race car and wasnt even touching 13s (it was a warm day out)!
Originally posted by Dennis91RSi thought about getting the S/R World Product heads for the 305 and going up to a 650 holley
Originally posted by Dennis91RSthe rear has 3.42 with an auburn pro series posi trac
Originally posted by Dennis91RSthe mods now pushed it barely into the 13s. Maybe, just maybe i can put the ole 305 into the 12s at 100+ mph
If you're confident you can get it down to 13.4 or 13.3 with a head/cam/carb swap... then lighten the load as well. Fiberglass hood, notch, doors (while relocating the battery to the rear) should do the trick.
Originally posted by Spectre.thats alot of stall
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Originally posted by tpivette89
obviously that car had issues with either its setup, or the driver. Dennis91RS proved you obviously dont need a "race car" setup to crack 13s in a 305
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
