Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1973 Rx2 v.s 1991 Camaro RS
Old Aug 26, 2005 | 12:20 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Rx2 Specs
1973
1.3 Liters
T2 Transmission
1/2 bridge port, S5 13bt, 720ccprimarys, 1600cc secondarys, S5 turbo hybrid with t04b compressor, .60 a/r t04 compressor housing, haltech e6k, 14X16 3" intercooler.
V.S.
RS Camaro
1991
305 5.0 Liters
700R4
Old Aug 26, 2005 | 12:21 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
So who will win from a dig?
Old Aug 26, 2005 | 12:54 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
You're kidding right?
Old Aug 26, 2005 | 01:01 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Old Aug 26, 2005 | 01:39 AM
TexasLT1's Avatar
Car: '92 RS
this is the only performance info I could find on the RX2's 12A rotary,
"97PS/6500 134Nm/4000"
So if someone knows what the conversion from PS (?) to HP, there you go.
the torque comes out to 98 ft-lbs for a stocker, and I guarantee that one isn't putting out much more. so uh, you tell me which one you think is going to win.
Old Aug 26, 2005 | 03:06 AM
stu's Avatar
stu
You're toast. Better luck next time. Maybe you should pick on something more your speed like a Cavalier or something.
Old Aug 26, 2005 | 07:25 AM
AcidShock's Avatar
As mentioned in the modifications for the RX-2, there has been an engine swap. The car uses a S5 13bt which is a series 5 1.3 litre turbocharged engine. Definately not the stock one.
The S5 13bt was capable of 200 HP (141 kW)... now keep in mind that was in bone stock form. That engine has been ported. A rotary cannot be bored out so it gets ported which allows better breathing and more fuel hence the upgraded fuel injectors.
That engine also uses an upgraded turbo as well as front mount intercooling. That allows a potentially higher boost level and more power. An aftermarket ECU controls the whole thing and if tuned well it is easily making in excess of 225 HP.
It does not look like your car has any modifications other than the hood, correct me if I am wrong but even if you did you would be hard pressed to beat this light RX-2 anyways.
Old Aug 26, 2005 | 07:43 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
if your numbers are right, that strange looking car is going to edge out the camaro.
wtf this is still one of the weirdest posts ive seen in here
Old Aug 26, 2005 | 08:44 AM
patRIOTik's Avatar
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
Zing.
Old Aug 26, 2005 | 09:35 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
I wouldn't be it, I'd trash it. Literally.
Recycling saves the environment
Old Aug 26, 2005 | 01:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is an RX2? Even if it makes 200hp what does its powerband look like and how much does it weigh?
Old Aug 26, 2005 | 01:12 PM
stu's Avatar
stu
Edge it out? with what that RX-2 is packing, he's not even going to have a chance. You'll win if his transmission falls out onto the ground, well maybe, it depends when.
Shifty: If I had any money, I'd bet $50 that the RX-2 weighs less than my car did. My car weighed 2550 with me in it.
Old Aug 26, 2005 | 01:19 PM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
Now you got two big gapping holes in your hood, but your not running an open air element yet? Why go though the trouble of cutting the holes and welding the scoops on? If his motor is producing over 200 hp and looks like the car weighs 2500-2700 lbs he has you beat. I kinda like the rx2 in a "you dont see those every day kinda way." that thing might give a srt-4 a tough time if hes got the motor done right.
Old Aug 26, 2005 | 02:36 PM
Car: '72 Chevy Nova
Transmission: TH350
Yeah if it's got 225 hp and it weighs 2400 lbs. Look the f*ck out cuz you're in it's way!
Old Aug 26, 2005 | 03:23 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
You gonna get toasted. Btw, nice hood
Old Aug 26, 2005 | 04:14 PM
AcidShock's Avatar
An RX-2 weighs in at about 2,255 pounds or 1,025 Kg. The powerband is variable dependant on the type of port job and the forced induction used. I would say that the thick of his powerband runs from 2.6K RPM all the way up to the 8K RPM redline. A rotary engine build more power the higher the RPMs go to a point. This is especially true with forced induction setup.
Also, do not count on the transmission taking a dump either. The ribbed turbo II transmissions are beastly.
Old Aug 26, 2005 | 05:01 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
i didn't even understand th list of mods but then agian i'm not much of a rotary guy.
Old Aug 26, 2005 | 05:06 PM
AcidShock's Avatar
That is why I have chimed in here. To make sure that if anyone has a question or does not understand something that the right information is given.
Old Aug 26, 2005 | 05:16 PM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Nice hood
I gotta say you are about to get whored....badly....by the ugliest car Ive ever seen....sorry bout your luck. GO race a Sunfire...nope, thatll beat you too. Damn, I guess stick to HOndas???
Old Aug 26, 2005 | 05:53 PM
stu's Avatar
stu
I was never afraid of any POS Sunfire or Cavalier in any of my Hondas. *shrug*
Old Aug 26, 2005 | 05:55 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
What in the world is up with that hood?! LMAO!!!
Old Aug 26, 2005 | 06:13 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Godzilla Defence Force vs. Thirdgen secret weapon.
Bring it on guys!
Old Aug 26, 2005 | 06:15 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Comming this fall to theatres near you!
Old Aug 26, 2005 | 08:08 PM
trainwreck517's Avatar
Car: Rx-7, Rx-2
Engine: 13b wankel @ 18psi GT35R
Hey, well that is my rx-2 posted upt here. Quick specs, car has been gutted, light weight bucket seats 15lbs each are replacine the 120lbs stockers. The car should weigh in alittle under 2000 lbs.
Car should be putting out about 300rwhp at about 10-12psi and should be in the low 12s high 11s.
And thank you guys for telling him what I told him myself.. I'm going to make him cry.
Old Aug 26, 2005 | 10:30 PM
stu's Avatar
stu
He should change his name to trainwreck, then stop posting.
Old Aug 26, 2005 | 11:12 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I'll still race you!
and remember you still have Ulysess Dodge Ram to race
365hp
Old Aug 26, 2005 | 11:16 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
You should join the Honda forum!and stop posting here
Old Aug 26, 2005 | 11:17 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
with youll cheap *** FWD buddies!
Old Aug 26, 2005 | 11:26 PM
Demon355's Avatar
...your an idiot
Old Aug 27, 2005 | 12:22 AM
Car: 1997 Corvette
Not some of the brightest words coming from somebody already on probation..
I gotta say that RX-2 is one of the most hideous things I've ever seen, but that is AWESOME. My friends and I were gonna hope to get about 300rwhp in a ~2100lb car as well (an '88 Chevy Nova...probably even worse looking than that RX2). Perfect sleeper car I'd say.
Hey Psycho kid, you'll still beat him. Now with that, bet him your computer, and race him. That way we don't have to read any of your posts anymore
Old Aug 27, 2005 | 12:24 AM
Car: 1997 Corvette
And so nobody can come back and use this against him, I'll bring it up..
Originally posted by Steve383
...your an idiot
He meant "...you're an idiot" I'm sure.
By the way, Steve, I love the look of that car with the single stripe down the middle.
Old Aug 27, 2005 | 12:33 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
WTF ???
I did a search for seats. .and I ended up with T H I S ????
Old Aug 27, 2005 | 01:25 AM
Car: Rx-7, Rx-2
Re: WTF ???
Seats:
http://www.jegs.com/cgi-bin/ncommerc...47&prmenbr=361
Thanks for playing.
Old Aug 27, 2005 | 02:59 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
If I loose i'll loose if I win I win... doesn't matter to me mang!
I will race anything that challenges me! as stupid as that might sound.. Anyways I don't plan on keeping the 305 engine.
Old Aug 27, 2005 | 04:45 AM
stu's Avatar
stu
Re: WTF ???
First time? Bwahahaha.
PyschounderscoreCamaro: If you win? See Above.
Old Aug 27, 2005 | 10:07 AM
Car: Rx-7, Rx-2
YOu will race anything that challenges you? If I recall correctly you challenged me.. you also chalenged me in a dogde ram that you don't even own. Seems like maybe your trying to compensate for something?
And you don't plan on keeping the 305? Well I sure hope you have a machanic do the swap for you. You keep calling me to help you fix your car now with the stock enegine.. can't imagine one with carbs, you will be going carbs right? Or at least dirrect port EFI.
Old Aug 27, 2005 | 11:06 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
baaaah
Psycho, even though ya up in Torrance .. it's still California ... and the Governator has messed up the already harsh emission laws. Thing is... you'll have to smog the car every now and then. Learn the tuning .. ECM etc .. .heck learn about heads cams exhaust port and polish ... mostly upper part of the engine.. before ya go 383 .. learn the stock engine before ya try something new
Old Aug 27, 2005 | 11:55 AM
Flash's Avatar
Car: '90 Mustang LX
Engine: 5.0L V8
I think the only thing that could make that little Rx2 uglier would be psycho's hood on it.
Old Aug 27, 2005 | 01:02 PM
Demon355's Avatar
Couple beers and 3am is the reason for my spelling misconception. Forgive me...lol!
When I bought my car, I was weary about the stripe. But I've had so many people compliment it, that I think I'll keep it in my next paint design. It's original and I haven't seen it on another 3rdgen, thanks duron
Old Aug 27, 2005 | 01:15 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Ohh man don't remind me had plenty of those .
And ya, the stripe looks good .
Old Aug 27, 2005 | 01:21 PM
Demon355's Avatar
I see your in T.O
You have a cardomain or something that I can check your ride out? Where abouts in T.O?
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Cripley
Aug 17, 2015 03:35 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
