Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
SRT-4 vs 89 IROC-Z
Old Feb 17, 2006 | 07:24 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
SRT-4 vs 89 IROC-Z
Its an 89 IROC-Z with an LB9 and a small cam, larger injectors,TB Bypass, Cutout boxes, Full 3 inch exhuast, 700R w/shiftkit, 3.23 gears. I wanna know what you thin they both run in the quarter, who will win, looking for guess estimated times? Thanks. This is my new camaro so im not sure what it runs, all i know is that its a quick car. So whats see what you guys think.
Old Feb 17, 2006 | 10:07 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
a stocker srt-4 should be good for mid to low 14's. A stage one should be good for mid 13's, stage 2 are good for high 12's, stage 3 are hella fast. I raceds a stage 2 ( minus downpipe) from a dead stop and he was really quick. He was next to me till the end of second gear, by the end of 3rd he was 4-5 car lengths back. I finish my 1/4 mile in the middle of third gear.
Old Feb 17, 2006 | 12:34 PM
stu's Avatar
stu
Stock are good for mid to low 14's a MILE above sea level.
Old Feb 17, 2006 | 03:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
SRT4's at my track are low 14's, some crackin high 13's. trappin like 95-99. not sure if any are modded. still pretty quick cars.
what cam u got in that Lb9? small cam to me means your not gonna win. from a dig is your best bet.. but i think you'll get pulled slightly
Old Feb 17, 2006 | 03:30 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
from a dig is your best bet...don't even try from a roll against those thing with a near stock lb9.
Old Feb 17, 2006 | 04:40 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
im confused... you say your 89' has the 305 in it, yet your sig states its a 350. which motor do you really have?
Old Feb 17, 2006 | 04:45 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
if that's all you got, you'll get spanked from a dig or a roll.
They typically run low 14s here at sealevel.
Old Feb 17, 2006 | 06:18 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Ya, low 14's is normal for those cars. Good luck, your going to need it.
Old Feb 17, 2006 | 06:57 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Hook and you'll get him outta the hole. But after 60 feet you'll be seeing his rear lamps.
Old Feb 19, 2006 | 03:48 AM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
I had an 87 GTA. L98, slp headers, slp y pipe, high flow cat, slp catback (two out the left), slp air foil, a chip, slp cold air intake, a shift kit and maybe a few other things like TB bypass.
I got walked by an srt-4! this was at Pittsburg raceway park! I kept up in first and half of second gear. granted my car had 145K and no rebuild, but still, its gonna be hard for you to keep up.
*edit*
I went 14.5 and the SRT-4 went 13.99
Old Feb 19, 2006 | 04:29 PM
Car: ws6
Engine: ls1
Transmission: m6
Seems alittle slow for that combo. Id think you would be in the 14.1-14.2 range.
Old Feb 19, 2006 | 05:01 PM
MidnightBlue07's Avatar
Car: Z28 / GT
Engine: TPI 5.0 / 3V 4.6
Transmission: A4 / M5
Axle/Gears: 3:23 / 4:30
Hey everyone I'm new to the forum and I've been reading what everyone is saying for a while and I agree wit you 89IrocZ , I also figured he will be in the low 14s with his mods
also aren't most L98 350s running mid 14s stock in the quarter?
Old Feb 19, 2006 | 07:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
On average yes. With exhaust and intake mods they should run 13.9's to low 14's (with proper traction).
Old Feb 19, 2006 | 07:18 PM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
srt-4s
i killed one with my l98 with esae .possible bad driveing from the other driver
Old Feb 19, 2006 | 08:33 PM
Car: ws6
Engine: ls1
Transmission: m6
Stock 87-89 L98 cars ARE rated as mid 14 second cars. Speaking from past experience I think they are more like high 14 second cars from the factory. The 90-92 speed density cars are a bit quicker. They make a little bit more power and also have lower gearing.
Old Feb 19, 2006 | 10:08 PM
This is not an L98 car its an LB9. so now what do you think its running high 14's-low 15's,, i dont know im just asking.
Old Feb 20, 2006 | 02:49 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
I have an SRT-4 as a daily driver and know these cars very well. The '03 SRT-4 is rated at 215HP, it has smaller injectors then the 04-05, and it has Michellin (Sp?) Sport tires stock, and is good for at least 14.1 in the quarter. The 04 up SRT's are rated at 230HP, and come with BFG KDWs, which are nearly like cheater slicks. The 04-05 is good for at least 13.9 with decent driver on the stock tires. Also, those HP numbers are stated as factory flywheel HP, but in reality those are what they actually put down to the front wheels, as proven on many occasions on the dyno. The 2003's also do not have LSD (basically posi for FWD cars), so only one wheel turns and obviously makes it harder for them to get traction. The 04 and up come with LSD stock, and if the driver knows the car well, these things chirp when launched, grab immediately and take off. Trust me, I know.
Also, the only 3rd gen I've messed with in my SRT-4 was a 305TPI / auto IROC. I don't know what exactly was done to it, but it was just one of those cars you could tell was a bit more than stock. It chirped into 2nd just when it was driving normally, and the muffler was about the size of a coffee can, as if it were just a resonator. We went at it on the freeway for a while, and he was a good 2-3 car lenghts back at least.
I couldn't tell you too much about your own car, but all I can say is, if you race, rolling or from a dig, make sure it's just for fun and no cash.
Old Feb 20, 2006 | 04:04 PM
stu's Avatar
stu
Threads like this make me consider buying an SRT-4 (because I can afford to now) but I think I'm just going to lease a WRX instead since I'm sick of FWD.
Old Feb 20, 2006 | 05:14 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I know someone that has a SRT-4 and a kid who has a 2.5RS Subaru(which IIRC is a lesser model of the WRX).
Overall I am much more impressed with the 2.5RS than I am with the SRT-4, much better looking car, a more well-built car, and a very well handling car, granted the subaru is a 2005 model, it is a superior car in my opinion.
And if your'e going to turbo a car, I think the 2.5RS would be a perfect candidate. Sorry for being off topic.
Old Feb 20, 2006 | 08:52 PM
stu's Avatar
stu
Why bother when I can just buy an already turbocharged WRX?
Old Feb 20, 2006 | 09:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
C'mon stu, you know you want a shi....box... I mean 3rd gen just like the rest of us. What other car can run 11's with that much primer.
Old Feb 20, 2006 | 10:37 PM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
What happened to the turbo miata ideas?
Old Feb 20, 2006 | 10:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
v8 miatas or LS1 Fd's
Old Feb 21, 2006 | 09:08 AM
stu's Avatar
stu
I'm torn between having just one nice daily driver till I can afford an even cooler car, or having a project Miata. I can get a 94-96 Miata with 50,000 miles for right around $6,000, but I've got horrible budgeting skills and have zero money saved. If I can get a loan to buy the car I'd be okay, but the turbo kit would be almost just as much (although it's worth it for what it comes with).
Plus, with three other roommates and only a two car garage, I'm going to just have this car sitting around all the time. It's too small and RWD to have as my only car as well. I still like the idea of 240 rwhp on a 2,000 lbs car on a totally stock motor. Then rebuilding the motor with forged internals for more boost later, but I have to seriously think about it on an economic scale. I wouldn't really be able to take anyone with me since it's only a two seater. I tend to be fickle with what I want to do about cars, but I'll figure something out.
Old Feb 21, 2006 | 09:12 AM
stu's Avatar
stu
Oh yeah. Insurance for the Miata would be way cheaper. I'm pretty sure I could get myself into a 2006 WRX for $20,000 though.
Old Feb 21, 2006 | 08:42 PM
Stu, could you get a low milage '05 STI for around the same as the '06 WRX?
Old Feb 21, 2006 | 10:03 PM
stu's Avatar
stu
No. Someone on my board keep offering '06 WRX's for right around $20,000 (msrp starts at $22,999) and '04-05' STi's with 20,000-30,000 miles are still going for around $26,000 I think.
Although, on a side note, I did used to sell used cars and know that average mark up was around $7,000. H1 Hummers were around $17,000.
If I could afford to lease an '06 STi I would. I only make $36,000 though. I think it'll be at least 9 months to a year before I can make my first move up to a higher salary.
Old Feb 22, 2006 | 10:30 PM
get the WRX then and make some "smart" mods that will net you results and not hype...like some guys i see driving around here with their wait till tomorrow turbo lag cars lol!
Galaxie500XL
Feb 1, 2020 04:53 AM
88CamZ
Oct 8, 2015 10:29 AM
86z89iroc
Oct 5, 2015 01:04 PM
Linson
Oct 1, 2015 05:33 PM
TexasMaro
Sep 15, 2015 06:50 PM
