Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
231 Vs 305?
Old Mar 20, 2007 | 12:16 PM
Quasi-Traction's Avatar
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
231 Vs 305?
A guy I work with wants to race on Friday....not sure if I want to do it.
ME:
2001 Camaro, 3.8L V6, 5 speed, 3.23 torsen rear, Hooker 2" Y-pipe (the factory exhaust sucks on 3rd/4th gens), 2 1/2" aft-cat exhaust, Flowmaster 80 series, with dual outlets. GMS airbox, K&N filter.
Best time slip to date: 15.68 @90mph, 2.11 60', .131 R/T.
HIM:
1983 Z/28, 180K L69, T5, Emisson Control/ECM deleted, Edlebrock 600, Edlebrock Performer manifold, AC delete box, 3.73 posi rear, Hooker Aerochamber, with 2 1/2" dual outlets, Some generic brand of shorty headers (he doesn't know either, car came with em..)
No timeslip to boot.
How badly am I gonna get beaten?
Old Mar 20, 2007 | 01:18 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: 231 Vs 305?
I believe it will be a drivers race.
Old Mar 20, 2007 | 06:38 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
Re: 231 Vs 305?
+1, that 3800 needs a driver mod to, is it a Y87?
Old Mar 20, 2007 | 06:49 PM
Re: 231 Vs 305?
Couldn't find it on the RPO sheet anywhere....so I guess that's a "no" to being a Y87 car.
Do you really think it'll be that close?
I'm not sure how much better a driver I am than him......hmm...I think I'll do it..I'll post back with the results.
Old Mar 24, 2007 | 06:57 PM
Re: 231 Vs 305?
well, the results are in:
I BARELY beat him....I beat him out of the hole and through the top of first, he started pulling on me in second, and was about 1/2 a car length ahead all the way until about 80-90mph....then I started to slowly pull ahead...I backed off the throttle at 110mph and his nose was parallel with my driver door.
it was indeed a drivers race. I think if he'd hooked before I did, I couldn't have made up the slack, or it would have been a tie. neither of us missed a shift, he said he lost a bit of traction out of the hole and from 1st to 2nd also. I blame it on him having more low end torque than me and his gearing.
I'd love to do it again...this time at a track!
If the weather permits the weekend after next, its on!
Old Mar 24, 2007 | 07:30 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Re: 231 Vs 305?
Sounds about right. I wonder what kind of tires, or at the least the condition his tires are in. Makes all the difference in the world. Right now my car is traction limited due to running only 17x8s, which apparently even with Pirelli PZero Neros doesn't put up much of a fight against 460+ TQ.
Old Mar 27, 2007 | 07:06 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Re: 231 Vs 305?
I'd say you got pretty lucky that his car is either out of tune or just tired from being old. I had less mods than that and ran a 13.89 back in '87 with my 84 HO 5spd. And yours should be running a little better than it does. We had a couple of the 3.8 cars in the 14's around here.
But it sounds like you guys had a great race. Always pretty cool when it just fenders and doors going thru the gears
Old Mar 27, 2007 | 09:07 AM
Re: 231 Vs 305?
I dunno if elevation or climate would factor into the tune of my car, would but where I live is about 60ft above sea level....
I can't speak about how well tuned Matt's (guy I raced) Camaro was.
We've been S---talking each other this week (all in fun, of course), he's itching for a rematch.
Old Mar 27, 2007 | 03:06 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: 231 Vs 305?
Both times sound about right. Come on guys, 180k on a 305 is pretty darn worn out, it is certainly not going to be running like new times. And a stock 3.8 is not a 14 second car by a long shot. Sounds like a good run.
Old Mar 27, 2007 | 04:48 PM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
Re: 231 Vs 305?
3800 coupe with the y87 actually can see high 14s
200k on my 305 and still runs like a champ
Old Mar 27, 2007 | 04:59 PM
Car: 2000 BMW M5
Re: 231 Vs 305?
Runs like a champ does not equal every bit of power as day one from the factory. Point is it sounds like they are getting reasonable results for real world driving and they were pretty well matched.
Old Mar 28, 2007 | 03:31 AM
Re: 231 Vs 305?
Originally Posted by abyliks
3800 coupe with the y87 actually can see high 14s....
Dream on. I'll openly admit, I'm a novice drag racer at best, but even on an mostly stock N/A, 4th gen 3.8L F-body, you'll never be kissing 14's without a less than a .030 R/T, and a less than 2.00 60'...which as I've discovered without a chip/TB and cam, is damn near impossible on street tires in the most ideal conditions.
maybe I'm being an A-- here, but if I can get my ET down by 2 tenths, on this car, I'll be thrilled. To me that's impressive improvement.
Old Mar 28, 2007 | 09:08 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: 231 Vs 305?
Reaction time is irrelevent.
I ran a 15.67 @ 89.88 MPH with a 2.35s 60' in my '97 RS. It had a T-5, 3.23 open rear, 17x9's with 275/40/17's, RKSport headers, high flow cat and a Flomaster 3" Exhaust.
14's should be do-able with a good launch and a 3.42 rear (Y87). I'm skeptical it could be done on street tires though.
Old Mar 28, 2007 | 02:46 PM
Re: 231 Vs 305?
I'm not sure 3.42's would make THAT much of a difference. DR's or Slicks...definately. The 3.42's would maybe raise your 60' by a tenth or two if you hook right away.
I used to launch pretty low, but I could never trap anything better than high, high 15's or 16's. I've learned to launch about 500-700rpm higher.
at the trap, I've either just shifted into 4th or about to as I cross the line (depends on how much I spin from out of the hole).
Old Mar 28, 2007 | 03:55 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: 231 Vs 305?
I always just rode it out in 3rd through the quarter in that car... never hit the rev limiter (probably a matter of tires). If you want some nice gains in that V6, I'd suggest grabbing a "VS" camshaft from ZZPerformance.com, I dropped one into that car and pulled ~210 RWHp on the dyno with the other mods I listed. I never got to run it at the track after that mod though it was pretty mean for a N/A 3.8L.
Old Mar 28, 2007 | 08:06 PM
Re: 231 Vs 305?
until I get my 3rd gen rolling again, I can't afford to have my 4th gen down, because its my only car.
probably keep the stocker cam in it...its just the daily driver workhorse. I'd rather have it be a moderately fast car, that gets relatively decent mileage, and is fairly reliable.
I'd rather throw money/time/mods at the 3rd gen. That one's just for go-fast fun.
Old Mar 28, 2007 | 08:09 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: 231 Vs 305?
I got 31 MPG highway post cam swap. I sold it to my dad and he's put about 12k miles on it and I had about 5k on the cam at that point... still reliable as hell, they're definitely awesome engines. Car has 152k on it now.
But yeah I know what you mean... one project car at a time.
Old Mar 31, 2007 | 09:36 AM
'86 350's Avatar
Car: '86 Camaro SC
Re: 231 Vs 305?
You realize R/T has nothing to do with your overall time right? There's people out there with the 3800 cars that are hitting high 14's.
Old Mar 31, 2007 | 11:11 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
Re: 231 Vs 305?
i know gtek times don't count but i gtek a 15.4 with a full tank of gas passenger and subs in my 96
Old Apr 1, 2007 | 03:09 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: 231 Vs 305?
Just an FYI, R/T has nothing to do with ET. 60 Foot time, on the other hand, is most of the race.
Old Apr 6, 2007 | 07:56 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
Re: 231 Vs 305?
I dunno man. My L03/Auto 2.73s RS ran a 15.7 with over 200K. That can't be too much slower, if any, than what it was capable of in 91.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
