How to keep old motor alive at the track
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
hey guys, i have a stupid question to ask. as the thread says, how do i keep my 192k 305 alive. i want to take it to NED next summer, but im afraid that it'll crap out after one trip down the 1/4. the motor runs like a top, but i don't think the bearings will like 5000rpm too much. anything i can do besides rebuilding the motor? Jim.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Re: How to keep old motor alive at the track
5000rpms aren't that much spin it up there.
If you're afraid of going WOT and spinning your engine past 4999rpms then what's the point?
Car: '82 Z28
How many times have you taken the engine up to 5000 on the street? How many of those times did you find yourself stuck on the side of the road with a blown engine?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Rag it like your gonna drive it. If it is going to break then there is nothng you can do about it.
Engine: L98 & L03
well, my 305 TPI i had in my blazer tapped out pretty quick when i started beating on it. as for this engine, i personally haven't even had it up to 4000rpm. it runs quiet and smooth, but im a-scared.
i just down want to end up with another yard decoration.
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
you'll be fine i got a 305 with 147000 miles and a rebuilt top end and that cars been beaten up its whole life. I recently put in a t56 and 3.73's and i get on that thing and hard and its still holding up.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Things you should do are replace your oil with some Rotella T. I would put the older type straight 30 weight in it but if it holds good pressure now you'de probably be better suited going with the synthetic 5 w 40 (this oil should cost you less than $20 to change to and is very good stuff; made for diesel engines). You should also consider replacing your valve springs. If a valve drops your motor is done. While you're in there do the valve seals and you should be good for another 100,000 miles. Also 5000 rpm isn't a very big stretch for these engines so long as you keep good oil in them and keep them at a normal operating temp.
Engine: L98 & L03
synthetic 5 w 40 Rotella? didn't know about that. as its time for an oil change anyway, ill be doing that i guess, along with a PH5. why did GM use the smaller filter? there not a clearance issue, so why not get the biggest filter you can fit?
i've also come across an other 305 from a TPI car, so i think ill do a little work to those 081 heads. LT4 springs and retainer should drop right in right? plus now i've got a backup engine should this one crap out.
Yes springs and retainers will swap right over.
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
I take my winter rat Escort past 5000rpms on a daily basis, thats got 195k on it. I take my 305 to 5500rpm every single time I drive it, I'd go further but there's no power past that point. My 158k mile 3.4 liter v6 in my wifes car, that sees 6200rpm on at least a weekly basis. Point is - you might as well go for it, the age factor alone isn't going to cause a failure within normal operating rpm, and if you do have a failure, you had other problems anyways that needed fixing. You've got a spare motor, so no sweat right?
