how to take down a ....well again
Car: 1988 sc camaro, 1986 IROC
Engine: 2.8 v6, 305 tpi (for now)
Transmission: automatic, auto( for now)
okay i started this thread a while back asking if there was anyway to mod out a 2.8l v6 to race against a bone stock 97 mustang with a v8.
obviously it just turned into a flame fest.
or everyone told me to swap to a v8
basicly i'm updating the odds, and again i ask a stupid question, yet less stupid.
his stang vs my camaro, except with a 4.3 v6
once again the question is, are there any mods to this engine i could run to make the race in my favor.
or is it just not possible for me to beat him without a v8
i'd rather not use nitrous,
and please no turning this into a bash
his car
mine (ignore the date, i never set it from the camera, it was taken about a week ago)
also he claims it to be a gt
but i'm 99% sure thats
his car
Last edited by wulfgar the pen; Dec 20, 2008 at 10:06 AM. Reason: Automerged Doublepost
Car: '89 IROC-Z
Engine: LSx
Re: how to take down a ....well again
Well to swap a 4.3 is going from a 60* motor to a 90* so you might as well do a sbc, plus 4.3's only really made power in vortech form which has the spider injectors, a pita. A direct swap would be a 3.4 out of a 93-97? camaro/firebird. That with a top end swap and some other bolt-ons should run with the stang(also depending on gearing). Or just do some searching and read daves sticky and do a turbo install, that done right should give that stang a run for its money. Plus if you need a hand I'm 10 minutes down the road in Killingly. James
thanks. i'll look into the 3.4
i had the 4.3 idea because somebody had said it was one of the most powerful v6's that would fit directly, but if it doesn't i might as well do a v8 swap than a 4.3
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
if that is all stock stang,the wheels are not (gt) style
ive only seen those wheels on the v6 models
at least around here anyway?
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I would just save and swap a 350 in. If you can find, and build up a 3.4 for cheap (and I mean real cheap) it might be worth it, but I have a feeling your going to spend a lot of time, money and effort to have a 14-15 second car. Why not build a 350, and drop that in?
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Not sure how a 6 cyl camaro will fair against a 8 cyl mustang. I own 6 cyl mustangs in my 305, and its always a good race with the 4.6 and 5.0.
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
im going to go against my instincts here seeing as you seem quite set on a v6 swap.. if you dont mind me asking why?? gas mileage??
anyway if this is the case hunt down a wrecked s-10 zr2 and get the 4.3 from it (the zr2 4.3 made 210 horse witch is more than the lower end modle 4.3)
there are a few places that do make crazy stuff for these engines (mostely designed for mad offroading but it would do) if you want em ill send you a link to some sights that make cams, headers, underdrives, carb swaps ect. with all the mods (about 3 grand worth) it would most likely up that motor to around 290-maybe300 hp
NOW the better idea but much harder to find, hunt down a Buick Gran National it should have a turbo v6 in it that will swap over very easy exept i think you will need to get somecustom manifolds made.. aside from that those motors stock from what i hear can handle stupid amounts of boost. get it in a put a bigger turbo a FMIC SSBOV have it tuned and get a fuel pump adequite for it.. you should walk on territory of even ls1
Car: 07 Saab, 88 Turbocoupe, 85 XR4Ti
Engine: LP9, 2.3t, 2.3t
Transmission: 6 speed auto, t5, t5
Axle/Gears: ? , 3.55 8.8", 3.64 7.5"
Why not use a 4.3? It's like a 350 with 2 cylinders lobbed off. I like the idea really. There were also turbo versions of the 4.3 so there is some direct aftermarket there. A lot of 350 parts will fit and there are even some improvements in the block and head design over the old 350.
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
if your going through the trouble of an engine swap theres no reason not to do some sort of a sbc, you could double your horsepower over the stock 2.8 very easily
It's just much cheaper to put in a SBC in a car that was designed for one. The Fbodies never came with a 4.3L so it's slightly more difficult and you can easily make more power even with a small V8, like a 305.
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
My thought for you is this; if you are set on using a v6, use the 3.8L from the '93+ F-bodies. The 3.4L is considerably underpowered for an engine with the same external demensions, which is why the 3.4L was dropped in the late 90's. I have seen quite a few 4th gens rock with that 3.8L using only minor tuning, bolt-ons and a supercharger, many of them out running the stock LS1s. I know a supercharger might be a bit on the spendy side, but consider; in the late 90's Buick began making a supercharged version of their Regal sedan. That v6 was a 3.8L, and for a fairly heavy sedan the supercharged Regal was fast. Yes the Regal is FWD, but near as I understand (I have not tried this yet), it is only a change in mounting brackets and some other hardware to convert to RWD. I am sure with a little patience and some digging might get you a solid engine from a junked car for a reasonable price. There are plenty of 4th gen owners dedicated to their v6 cars and a descent aftermarket to support the engines. If the conversion project (from FWD to RWD) sound like too much, I would just try to pull a 3.8L and tranny from a 4th gen and start there. Most aftermarket companies offer support for these engines.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
You can mod a 4.3 to handle a good bit of power. I plan on putting one in a chevette here shortly but I agree it would be just as easy to swap in a SBC. Or you can turbo the 2.8, just depends on what route you want to go.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
A 4.3 with 290-300 hp for $3,000? Yeah right. 400 hp for $3,000.
Get a 4.3 roller block, not one that uses a balance shaft, vortec heads, headers (that's the expensive part, if you can't make them yourself) 14:1 pistons, roller rockers, have comp cams make you a cam... This is less than $2,000 and makes about 340 hp. Motor mounts might be the only difficulty in mounting this engine to a third gen. Costs about the same as a sbc, but it's a lot more satisfying to beat on mustangs, then tell 'em you have a v6.
If you add forced induction to this, along with the fact that it weighs 25% less than a sbc, and gives you near 50/50 weight distribution, you could see some air under the front tires.
Car: 1984 z28 camaro / 2019 accord sport
the motor your talking about is a l67 it comes in quite a few gm cars. I have one in my regal the come in grand prix gpt's to name a few. i am not quite sure how easy it would be to convert to rwd
kd5icr
Sep 2, 2010 10:27 AM
brandon_mckay
Feb 8, 2009 03:07 PM
