Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
me vs a 90 probe GT turbo 4 banger....could he win if he boosted his turbo up to 10.8
Old Oct 27, 2001 | 12:55 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i gotta friend that has a 90 probe gt...its a nice little car but he thinks its a racer and it startin to **** me off.....one day he tells me he knows his car isnt that fast and he is gonna "pimp" it out...but then he starts tellin me all this crap about boosting his boost to 10.8 psi and puttin a lil cold air induction thing on his car that the people on his message board said would make a BIG difference....well do you guys think he would have a chance against me
we have raced b4 and i KILL!!! him off the start and then when that turbo kicks in his acceleration is about as good as mine but by then he is 3 or 4 car lengths behind me....my car has not had a tune up in like 4 years but it was sitting for 3 of the 4 years...and i think it might need some carb work cuz 2nd gear takes FOREVER to get through!!!
well anyway what my point is....what could i do to make my car faster...i just added a hooker exhaust to my car like 2 days ago ( i raced him with my old STOCK exhaust)....and i am hopeing to do a cold air induction but i dont know how to do it the best...i was going to run it to the side fender wall and down to the undercarage, but then the air would b all twisted and it probably wouldnt help me much...right??
well if any of you know where i could run a cold air induction for my CARBED L69 or any other performance tips please resond!!!
thanks
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
Old Oct 27, 2001 | 11:19 PM
prepz28's Avatar
i raced a car similar to your friends and he ran a 16.4.
Old Oct 27, 2001 | 11:48 PM
Chevy83Z28's Avatar
First power mod.. a TUNE UP!! You say the car's been sitting for 3 years? Automatically... oil change, coolant flush/new thermostat, new hoses/belts. Brakes may probably need rebuilding too-not necessarily for power, but to stop! Possibly replace spark plugs/wires, check the timing.
What good is a high flowing exhaust if you don't have proper combustion and the engine runs rough? Tune the carburetor for air/fuel mixture and idle speed (can you do this on the computer controlled carbs? I still havent figured it out on mine.) If its a high miles engine...maybe even change the timing chain.
Start with the basics, then add the power-adders, you'll be better off!
Old Oct 28, 2001 | 04:57 PM
JR4444's Avatar
My friend had a front wheel drive turbo eclipse, and he had to boost at 28LBS and he olny ran a 14.2, thats pretty $hity.
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, Custom Burned PROM, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler,
Old Oct 28, 2001 | 05:04 PM
SPOOM's Avatar
"My friend had a front wheel drive turbo eclipse, and he had to boost at 28LBS and he olny ran a 14.2, thats pretty $hity."
There's no way on earth he's running 28 lbs of boost. Absolutely no way. Even with an upgraded turbo, 28 lbs of boost would be impossible/suicide without running racegas ALL the time.
What times does your 3rd gen run?
SPOOM
92 TSi fwd
[This message has been edited by SPOOM (edited October 28, 2001).]
Old Oct 28, 2001 | 06:14 PM
JR4444's Avatar
I was jut going on what he told me about the boost. He did have a bigger turbo...but if that's impossible to run that much I'll believe you. I'm taking the Formula to the track on Saturday and I'll post the times on the TPI board.
88 Formula 350
Old Oct 28, 2001 | 10:06 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I'd worry a little about your friend's turbo 4 banger, if he gets someone who knows what they're doing to set up a bleed/boost controller and cold air, IT WILL give him alot more power.
I know of a guy with a talon/eclipse AWD running 24psi into the stock heads/cams/engine/etc. just an upgraded turbo/fuel/intercooler?(probably).
My advice would be worry about your car going faster than 15.9, b/c you're the favorite victim of all those rice burners, A LOT of them that aren't total posers run mid 15s to high 14s around here (FL). I'm sure they'd just love to beat up on a stock camaro or firebird.
Cheap stuff for a carb car. cold air like you said(can make it for less than $50) ,HEADERS, cheap high flow cat or none, intake manifold (edelbrock etc.), tune up. less than $600. If your car is 5spd, that should put you into the 14s easy.
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Oct 29, 2001 | 06:20 AM
SPOOM's Avatar
"I was jut going on what he told me about the boost. He did have a bigger turbo...but if that's impossible to run that much I'll believe you. I'm taking the Formula to the track on Saturday and I'll post the times on the TPI board."
If he says he's running 28 lbs of boost on the street, then he's definitely lying. If he's lying about how much boost he's running he might be lying about his turbo also. Who knows, maybe he's lying about his timeslip, too (although 14.2 is very believable). A 14.2 can be achieved with SUBSTANTIALLY less than 28 lbs of boost (more like 15-17 lbs, depending on presence/absence of exhaust mods) with the stock turbo and decent traction in a fwd DSM.
Good luck with your times, by the way!
SPOOM
92 TSi fwd
Old Oct 29, 2001 | 08:19 AM
Ben87GTA's Avatar
heheh 28psi for 14.2. maybe if he runs it in reverse My friend has a talon, early 90s model, and he runs mid-high 11s all day and night in that thing. i'm scared of those cars but, as far as the topic is concerned, I wouldn't get too cokky (yes, i know it's spelled incorrectly..stupid word filter..) with your L-69 vs a turbo probe. I've seen a few of those get up and move... and a not properly tuned l69 isn't lightning. Bottom line: run him, have fun, but don't run him for slips- you just may end up walking home that night.
Decently worked 87 GTA; still slow running 13.46 @ 114.3mph
huh, what the f*ck is traction?!
[This message has been edited by Ben87GTA (edited October 29, 2001).]
Old Oct 29, 2001 | 09:04 AM
85transamtpi's Avatar
This probe guy reminds me of my friend with a early 90's dodge daytona turbo. He cranked up the boost to 15lbs, put exhaust on, a bigger throttle body, and some suspension mods. He still gets spanked every time by my buddies 96 monte Z34 (stock). He wont even try against me 'cause he knows what'll happen.
Give your car a tuneup, and hang out in the carb board. Some of those L69's are pretty quick when everything is all tuned up. Anyone can take a piece of sh*t and put a turbo on it, and in the end all you have is a turbocharged piece of sh*t. Remember the turbo sunbird...LOL
peace
Old Oct 29, 2001 | 11:34 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
alright well i dont really know how to tune these kinda carbs
if it were a holley my bro could do it in no time
is there any place where i could take it to and they could do the timing and the fuel mixture and all that stuff
my first gear feels really fast but my second feels really slow and thats why i think my car might not b running at max performance
and no i WISH SOO MUCH that mine were a stick but i gotta 700R4.....but someday i will drop in a 2500 stall and a better motor and that will make things better
then he wont have a chance!!!
and yah i get the feeling that the only thing he wants to do is make his car faster than mine.....and that just pisses me off cuz it seems like he has to ALWAYS be better than everyone else.....once i get the 350 then he wont even come close
well thanks for the replies...after i pay my insurance i will try and find a place to get a tune up done and a place to maybe rebuild my carb and do some tuning
Mods-
K&N Air filter
Hooker Cat-Back
Old Oct 29, 2001 | 11:46 PM
ws6formula89's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ben87GTA: I wouldn't get too cokky (yes, i know it's spelled incorrectly..stupid word filter..)</font>
Word filter? What word filter?
What's so bad about saying "co<x>cky"?
-Todd-
Old Oct 30, 2001 | 09:32 AM
SPOOM's Avatar
"Anyone can take a piece of sh*t and put a turbo on it, and in the end all you have is a turbocharged piece of sh*t."
I was going to offer to show you my turbocharged piece of sh*t at the track, but then discovered that you lived nearly 400 miles away.
SPOOM
92 TSi fwd
$750 L98
Feb 1, 2025 02:25 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Dragonsys
Sep 25, 2015 03:51 PM
