Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Me vs 5.0 mustang
Old Nov 25, 2001 | 01:41 PM
89transam's Avatar
Me vs 5.0 mustang
Im sure this has been rought up a milion times but bear with me. Me and my friend are gonna race like thursday. He drives a 1984 Mustang 5.0 L . As far as i know hes got a rebuilt engine with new parts. He also said its a 4 speed manual, he dosent really have anything elce. BUt what I m wondering is that mabye his car is so light that it coudl stand a chance. WHat do you guys think.
Red 89 Trans AM GTA
T- tops
Engine stroked to 383ci
World Products heads
Elgin cam
GM 5.7 rods
Keith Black pistons
2-row timing chain
Mellins Hi-Volume oil pump
9:1 compression
24# Ford Fuel Injectors
Edelbrock TES Headers
hi-flow Catalytic Conv
SLP Stainless Steel Cat-back exhaust system
Torkmaster Torque Converter (2000 stall).
Old Nov 25, 2001 | 02:08 PM
Racnoth's Avatar
From you sig, I'd say you'd have him, as long as he hasn't done anything major, as in cams heads intake stuff. If he's done heads, cam, and intake, it'd probably come down to the driver and suspension...depending on what kind of cam your running
Old Nov 25, 2001 | 04:11 PM
89mustang's Avatar
Does he have new STOCK parts or new high performance parts. If he put a small carb and stock cam you will destroy him. But if he has performance parts like Cam, Heads, Intake, etc it should be a good race.
Old Nov 25, 2001 | 08:42 PM
89transam's Avatar
He has a few preformance parts, I think he has heads and a cam.
Red 89 Trans AM GTA
T- tops
Elgin cam
GM 5.7 rods
Keith Black pistons
2-row timing chain
9:1 compression
Old Nov 25, 2001 | 09:00 PM
89mustang's Avatar
You should take him, depending on the heads and cam he is probably running between a 13.8-14.8 if he can drive it. I think in the end you will win, but run the two and post.
Old Nov 25, 2001 | 09:10 PM
Racnoth's Avatar
not too sure on the gear ratios on the old 4 speeds. With heads and a cam, the car is opened up quite a bit over stock. However, those parts won't really work to their maximum without a decent exhaust, and a decently matched carb and intake. I'd say you'd still take him, my 5.0's stock, and it's still a bear to get traction off the line...your auto and 2000 stall should really help ya out there. If you've got some decent gears, I'd lay money on you.
Old Nov 25, 2001 | 09:27 PM
Mustang5L5's Avatar
I dunno....if it is STOCK, you have him beat. But depending on which heads and cam he has, he could be 15's...or he could be low 14's. You never know.
Mike
--Black '88 Mustang LX 5.0L AOD--
BBK Headers, Off-Road H-pipe, MAC 2.5" Cat-back exhaust, UD Pulleys
3.73's, FMS "C" Springs, Tokico Shocks,
'93 Pony rims, Saleen Spoiler
5-spd swap VERY soon
-14.42 @ 98MPH (w/ 2.4 60-footer)-
Old Nov 25, 2001 | 09:50 PM
89transam's Avatar
And I cant beat that?
Old Nov 25, 2001 | 11:04 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
ummm just wondering why there's even a question of a winner here..four eyed Mustang 5.0 vs. 383 stroker GTA.unless this mustang shoves a rocket up it's *** or has an insane amount of mods which it doesn't like it does there's no question the GTA is going to destroy it unless there's some unfortold act of G O D or something..
"Turn a 12 second dream into a 10 second reality"
Old Nov 26, 2001 | 07:44 AM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
I agree with CobraKiller
1989 Mustang LX 5.0 Coupe
13.29@106.66 - needs more gear and converter
1992 Mustang LX 5.0 Convertible
14.23 @ 95.something - 100% bone stock motor - it's been a while since I've ran this one
1993 LX 2.3L Hatchback - "The Ride to VCU"
Moderator Stangtec.com, SN95.com
Co-Founder, Tri Cities Mustang Club
Amelia and Nic's Twin Terrors
Old Nov 26, 2001 | 03:52 PM
Brett Gutshall's Avatar
Yeah you should have no problem with the 84 given your mods. They are 175 hp stock. My friends got one with headers, true duel exhaust with flowmasters, intake mods and an MSD ignition and I still smoke him despite my car being a little heavier. Also knew a kid with an 85 GT Vert. He had a cam, intake and a carb and ran 15.3. Respectable for an otherwise stock car, but I think I could have taken him too and I'm mostly stock.
90 Formula 305 TPI 5 speed
K&N, Dynomax Muffler
Coming soon (Hopefully):
85 Iroc 305 TPI Auto
Flowmasters, Ignition, Chip
87 Iroc 350
Bone Stock w/41k miles
The guy wants 2 g's for both
Old Nov 28, 2001 | 09:54 PM
89transam's Avatar
Well Im a call him tommarow (thursday) we shall see. I shall prevail
Red 89 Trans AM GTA
T- tops
Elgin cam
GM 5.7 rods
Keith Black pistons
2-row timing chain
9:1 compression
Old Nov 29, 2001 | 03:16 PM
12sMustang's Avatar
I don't know enough about what you run to make an informed answer, but if he's got Heads, and cam, and an induction system to match, and his car is tuned, his car could be capable of anywhere from mid 12s-high 13s.
Old Nov 29, 2001 | 03:41 PM
Mustang5L5's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 12sMustang:
I don't know enough about what you run to make an informed answer, but if he's got Heads, and cam, and an induction system to match, and his car is tuned, his car could be capable of anywhere from mid 12s-high 13s.</font>
Hard to know though without knowing exactly what it has. 84 stangs were slugs, but the 5.0 takes well to cams and heads and induction. I dunno though...tough one to call
Old Dec 3, 2001 | 04:08 PM
89transam's Avatar
Well it still hasent happened. Work school etc . BUt what do you consider decent gears? I found out some more stuff about my cam and stuff.
Lift 420/433
Dur 270/280
(204/214 at 050)
sep 110
My suspension is Limited slip 3.27 ratio
Aluminum driveshaft
Old Dec 3, 2001 | 07:34 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
c'mon guys thats a little rediculous..... do you really think that an 84 mustang 5.0 would be able to hang with the 89 GTA with a 383 stroker?? look at his mods that is so rediculous. i think you should race the mustang, and blow his doors off. i've raced my buddies 88 gt 5.0 5 speed a few times, and even though its stock, i havent gotten beaten down. look at my car in the sig.......
not really impressive
1987 LG4 Camaro z28
Mods- 80 series flowmaster, k&n filtercharger, open air element, cat pipe delete, 180* stat, edelbrock performer intake, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
Old Dec 3, 2001 | 07:58 PM
LincolnHawk's Avatar
You never know i once saw a escort take a gta
Old Dec 4, 2001 | 03:43 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
That was probably an 80's M*****g. If not, that was 1 mistuned GTA.
[This message has been edited by IROCZTWENTYGR8 (edited December 04, 2001).]
sammy52401
Nov 11, 2015 07:20 PM
ndndndnd
Sep 28, 2015 08:00 AM
okfoz
Sep 22, 2015 03:37 PM
