This car will make yours look like a turtle:
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Have you seen this, an electric that does 0-62 in 2.8 sec?
http://www.cnn.com/2014/01/23/tech/i...tml?hpt=hp_bn5
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: This car will make yours look like a turtle:
yeah things are changing it was hard for some guys to accept fuel injection and a computer way back in the old days
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
electric motors make full power from 0 rpm all the way up, they don't have to build power like our gassers do. my friend owns a tesla, and it's crazy fast on acceleration. A friend of mine also owns a four runner hybrid which is actually crazy fast too, but they don't have that cool sound....actually no sound at all. lol
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I'll stick with my turtle, I don't find pleasure in driving unless my eardrums are being assaulted.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
until batteries can match the energy density of hydrocarbon fuels, I'll keep my noise maker
My wife has a Volt. The acceleration is terrific, and it has dynamic brakes, recharging the engine when slowing down. For short-hop driving, it's ideal; 40 miles without engine assist. So far, 90 miles per gallon. Battery guaranteed for seven years. $7,500 tax credit and zero percent interest from GM. Cost: four cents per mile to charge. This is the future, and when it hits, car repair places will be fewer and smaller.
Has anyone put batteries in a 3rd Gen? It's inevitable.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I think the costs and amount of energy used to produce those electric cars make them not a viable alternative yet. Its taking more energy to make them than they save. I believe gm lost its rear end when it came to producing those volts. The potential is there just not quite effective yet.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The problem with electric cars is the batteries. For the amount of weight they add into a vehicle, the power capacity is pretty **** poor. Manufacturers are goint to have to use batteries that weigh 1/2 as much (as present packs), and have at least 2x the power capacity to make sense.
People love the Tesla, which is an almost 5000lb car as it sits. If they could drop that weight to 3500lbs and double the battery power, then it makes more sense. Ditto for the Volt or anything else looking for max economy - gas, diesel, hybrid, or electric.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Exactly, but the average person cannot comprehend anything other than what they experience as the end user. It would horrify the "green" type person who drives one if they saw the actual amount of waste and pollutants produced from the battery manufacturing process.
Yes, the Volt isn't cost effective; GM is losing money on each one, which is why it doesn't advertise the Volt. The tax incentive makes it viable; in other words, Washington is subsidizing GM's and Tesla's R&D, in a way that doesn't violate international trade treaties, because it's gambling the investment will pay off in the long run. I wouldn't bet against it, though the battle may be won by someone tinkering in his garage, as usual.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I do think electric, especially hybrid electrics, will come close to IC stuff, and pass it in some categories (trains already have!), but IC will be extremely relevant as long there is still oil in the ground. Short of the Rankin cycle, an IC engine burning hydrocarbons is hard to beat for efficiently producing shaft work.
Yes, an currently EV's and hybrids use more net energy than IC. Sadly many do not grasp that.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
a would not say a "typical" v8 is only 20% "efficient". The figure 33% works for most 4-stroke gasoline engines if your talking about % of fuel energy converted to shaft work, but it really depends on the exact engine.
I'm not exactly sure what your trying to compare between electric motors and IC engines when you say "efficiency", but I'll assume you mean converting available energy [electricity or fuel] into shaft work [HP]. The electric motor is going to be way more efficient that the IC engine, but you have to consider the whole package to make it a worth while comparison. That gets very complicated, and it's not easy to do a direct comparison, you really have to consider the life span of the vehicle, production requirements, etc. to make it accurate.
It's not the motor technology, but the battery technology and the whole converting chemical energy into heat energy into shaft work into electricity into stored energy and then into shaft work again, rather than just converting chemical energy into heat energy and then into shaft work like IC engine, that make EV's so difficult. Every time you change the quality of energy, you have losses.
Then again, thats the reason that hybrids like trains work so well, store tons of energy in a energy dense fuel, convert it to electricity, and then use high TQ electric motors to convert it to shaft work. Its heavy but doesn't need to be fast, so it works. It's all about optimizing really
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
but theres scientist always searching for new fuels...we will find the right one soon
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I commute 180 miles a day in a CNG Honda Civic. The gas is $1.85 a Gallon equivalent and I get 40mpg. It only costs me 10 bucks to drive round trip. I'll take that over electric any day.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
db057
Aug 11, 2015 10:11 PM
