Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Me vs S2000
Old Jan 25, 2002 | 11:44 PM
1992_25t_1letpi's Avatar
Me vs S2000
My 2nd cousins dad owns a 2000 honda s2000 base model with no mods. I know that i'll probably lose but how bad is what i wanted to know. btw i can shift he can't. also doesn't that car have a limited slip differential or something?
Old Jan 26, 2002 | 12:45 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Ive read that thy run high 13s, stock. Be careful.
Old Jan 26, 2002 | 12:59 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
numbers I am seeing from road and track
0-60 5.5
1/4 14.1
think they do have an lsd to them
but they are a PITA to launch
too easy to bog since all there power is in the higher rpms
and if you try to pull to high of rpms you just sit there and spin the tires
so even though they pull quick times if this guy can't drive you should take him
Old Jan 26, 2002 | 10:12 AM
Doski's Avatar
with my almost stock 350 i bairly won!!!
s2000 0-58mph is 6.2
Old Jan 26, 2002 | 10:32 AM
5.0mustang's Avatar
I say hes got you, but you have to launch those at like 6000 to get a good launch, cause if you don't they bog badly. Hope he can't drive, but don't underestimate him if you pull away off the start those things will chase you down when he gets into the powerband.
Old Feb 1, 2002 | 02:39 PM
iroc22's Avatar
I think you will take him. Does the S2000 owner like to rev to 9000rpm? he prolly will puss out because the car is brand new and he wont even get into the power range of the engine.
Old Feb 1, 2002 | 03:07 PM
I think so too. he is REAL careful over the car. nobody is allowed in it with their shoes on. i don't say he'd rev it past five, prolly think his engine is going to blow or something
Old Feb 1, 2002 | 03:12 PM
iroc22's Avatar
Well you know if he doesnt rev past 5000, he's prolly not going to get more than 140 horsepower to the ground and probably not more than 100ft-lbs of torque to the ground. I say you will kill him.
Old Feb 1, 2002 | 09:15 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I think it was either Car and Driver or Motor Trend that said to get those numbers and the best performance out of the S2000 you had to drive it like you were a teenager or you stole it(something along those lines). If I remember right, they rev to like 9 grand, I don't remember where redline started but I remember it being REAL high. If he's afraid to wind(sp?) out the gears and he isn't good with the stick, then I say you stand a good chance of puttin an S2000 on your kill list =)
Old Feb 1, 2002 | 09:29 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i actually raced one and i watched him do his other runs. the best he got was a 14.5 @ 95 and he was running it hard. it was funny because i was pulling on him at the top end and this was before i had the cut-out and had bad plugs and my time on that run was a 14.4x
it was close but they aren't all they are cracked up to be i don't think
Andrew
Old Feb 2, 2002 | 05:19 PM
iroc22's Avatar
It was Motor Trend that said that and they also said that they tried shifting at 5000rpm like a "daily driver" would and the 0-60 time was like 12 seconds. The redline is at 9000 and the hp peak is like 8400rpm. Real high.
Old Feb 2, 2002 | 11:42 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I definatly think you have this guy if 1) He can't shift 2) he's afraid to take it to red line. 4 cyl engines don't generally produce significant amounts of power in the lower half of the tach. However, don't quit till you win, cause those things'll have great top end.
Old Feb 3, 2002 | 12:09 AM
We'll i'll take him this spring and tell ya the resultes. I'm feeling confident, thanks guys
Old Feb 3, 2002 | 03:10 PM
I asked him today if he wanted to race in the spring and he said he'll think about it. then i ask what rpms would he be driving it to. Then he said 5-6500 and said thats the highest hes ever gone and that thats all he'll need to beat me. I guess its obvious hes never been in a ride in a camaro yet
Old Feb 3, 2002 | 09:58 PM
iroc22's Avatar
Haha yeah tell him good luck when he's only going to put like 150 horsepower to the ground.
Old Feb 5, 2002 | 08:57 PM
xxwarrior36xx's Avatar
If he only revs to 5,00 you'll kill him. The whole reason those are fast is the new engine. It opens up a whole new cam after 5500 rpm. he will run 0-60 in like 8secs. You should be able to kill him. My frind raced one off the line and just killed it. WARNING!!! if you race a long way he will kill you up high!
mrnegativity
May 12, 2009 02:35 PM
B.lane 88
26
Mar 2, 2009 12:45 PM
Wind Charger
Sep 21, 2005 05:24 PM
rx7speed
17
Nov 30, 2002 06:11 AM
TheRoc88
53
Aug 20, 2002 01:06 AM
