Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Dam car won't start after encountering rain!
Old Jul 19, 2002 | 11:49 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Yah so I worked at Yorkdale yesterday and left the car outside didn't think it was going to rain, and couldn't find underground parking.
When I finished work, I drove the car home, dried it off with a towel, and parked it in the garage.
Woke up, went to go start it, and it won't start. It just goes "jugajugajugajugajuga" but nothing happens!
The other thing I noticed is when I push the clutch down I hear a wet squeeking sound... hmm....!
I need the thing to start, any ideas!?!
Old Jul 19, 2002 | 12:06 PM
nblanchard's Avatar
Does your "Service Engine Light" come on when you turn the key on?
Old Jul 19, 2002 | 12:36 PM
no man, it's not an engine problem
it's probably some electrical problem, some wire is wet is my idea!
Old Jul 19, 2002 | 12:58 PM
sleeper's Avatar
remove the cap/rotor and blow it dry with a hair dryer. Also remove the plug wires one by one and look for corrosion or water.
Old Jul 19, 2002 | 01:26 PM
where is the cap/rotor???
Where are the wires. If you tell me where, I'll go do that! heh
Old Jul 19, 2002 | 01:45 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Cap/rotor is on the distributor.
Not meaning to sound like an ***, but you really should have had someone check the car out thouroughly before you bought it for $10,000. The could have done a load test to check your electrcial system and a whole whack of others so you could have bargained with the price more.
Old Jul 19, 2002 | 01:48 PM
where is the distributor?!?
Old Jul 19, 2002 | 01:50 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
very back center on top of the engine, it's the round thing all your plug wires go to.
Old Jul 19, 2002 | 01:52 PM
ok, so what do i do with it?
Old Jul 19, 2002 | 01:56 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Ok theres gonna be two screws holding down your distibuter cap. The cap is what all the wires attach to, its the big round plastic thing. You'll have to mark your wires somehow cause they have to go back in the same place. you only have to take off enough wires off the cap to get the cap off and expose the insides. The plastic thing on the inside is the rotor, when you can see that, take a hairdryer and dry both of them off. Take the wire off of your coil as well and dry the coil off just incase. The wire in the center of the cap(the shortest wire0 goes to your coil.
Old Jul 19, 2002 | 01:58 PM
isn't the big round plastic thing that all the wires connect to at the bottom right corner of the engine compartment???
like, if you're looking from the front....
|---------------xxx|
Old Jul 19, 2002 | 02:04 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
you have your TPI assembly at the top.
a
-- III--
--III--
--III--
-- III--
OK this cheezy diagram is your the top of your tuned port injection system. The III are the middle bulk part and the -- are the little spider legs or runners. The "a" is the distributor and is as close to the firewall as it can be. The distributer is about the size of a softball, you can't miss it. All of your wires go to it. You might have to unscrew the back plate of of your TPI system to access the distributor.
Old Jul 19, 2002 | 02:05 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
the drawing came out lopsided, the "a" should be center of the rest.
Old Jul 19, 2002 | 05:24 PM
trigger GTA's Avatar
Car: 92 TA vert
red with the yellow wires is the distributor. that is what they are trying to get you to remove.
Be sure to mark all the wires and where they go
Attached Thumbnails Dam car won't start after encountering rain!-engine-done2.jpg
Old Jul 19, 2002 | 05:29 PM
MR. JORDAN's Avatar
Wow!
That is all!
Old Jul 19, 2002 | 05:33 PM
darbleinad's Avatar
Car: 84 Trans Am
Trigger.......that is a great looking engine.....i love the read paint on the runners
Old Jul 19, 2002 | 11:05 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
No offense easyspeed, but if you're going to own a car like that, you might want to consider getting a Chilton or Haynes manual to familiarize yourself with your car. It will make it easier to help you out with your questions when you know what they are talking about. It will also save you tons of money, you wont have to take it to a mechanic everytime you need something small. BTW, I would have to say that by your diagram you were looking at the charcoal canister with rubber tubing coming out of it. If you just said "huh", then go out and get a manual and read up on it. Good luck...
Old Jul 19, 2002 | 11:53 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
thats what I should do also!
Old Jul 20, 2002 | 01:51 AM
Slade1's Avatar
I only mess with the insides of my car when I've got a good idea of what's in it to mess with. I refuse to be at the mercy of mechanics so I studied up on everything I could get my hands on in my car. I also have the benefit of my dad owning a bunch thirdgens prior and he always went in and messed with it all.
For the new guys to thirdgens, get a book. The basics are covered and although you may not get the urge to do a rebuild at least you'll know about the majority of parts in your car.
Kev, btw my egr is acting up on me so I was gonna clean it. What'd you use to clean it to get it all nice like that? Or did you do the sandpaper route?
I knew you guys were a curse to me lol.. I figured sooner or later the hell week would catch up to me and lo and behold.. a SES light!!! Itss intermittent, but the code stays in mem... Pulled a 32 out and got very very upset at the <1 year old egr that killed the rings on my block a few years ago... You think they make a "performance" egr lol? My car figured it didn't want to be left out of all the problems and decided just to annoy me it'll toss a 32 my way so it can be like the other thirdgens... typical.. its such a wannabe car.. it wants to be like the others lol...
Old Jul 20, 2002 | 02:29 AM
nblanchard's Avatar
dood.... does the yellow light on the dashboard that says "Service Engine Soon" light up when you turn the key to the "ON" position?
Old Jul 20, 2002 | 08:02 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Hey Slade, I used a dremel with a coarse grit sanding wheel on the base to remove the cast and then used sandpaper on the EGR itself. It's not perfect, but it will look better on the new intake.
I hope you figure out your code problem. Would you like me to look it up in my Haynes manual :lala:
Old Jul 20, 2002 | 09:20 AM
I took the distributor cap off and blowdried it, but the car still doesn't start. Everything coming out of the distributor cap works. The rotor works fine. The wires all seem to be fine. It's giving a spark to the sparkplugs.
I'm stuck, don't know what to do. Probably gonna call a towtruck, hate to spend another $100 but what can you do!
Old Jul 20, 2002 | 10:00 AM
Slade1's Avatar
Nah I know what code 32 means lol... me and 32 go back quite a few years lol... Code 32 is EGR solonoid failure I recall.. something like that. Thanks for the sanding tip.. that yellow brass color really bugs me... while I'm at it maybe a manifold paint job would be in order... would look nice hehe...
I don't think I've ever seen a thirdgen that liked that damn device... but with emissions, I'm stuck with it... maybe its time to look into an 87 older thirdgen and do the 350 boogie/hot rod status...
Old Jul 20, 2002 | 02:17 PM
nblanchard's Avatar
DOES THE YELLOW LIGHT ON THE DASH THAT SAYS "Service Engine Soon" LIGHT UP WHEN YOU TURN THE KEY TO THE "ON" POSITION???????
Old Jul 20, 2002 | 02:58 PM
ROCHEAD's Avatar
mine does heheheheh
Old Jul 20, 2002 | 05:34 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
same!
aaahhahahah
Old Jul 20, 2002 | 08:01 PM
no it doesn't light up!
Old Jul 21, 2002 | 12:14 AM
nblanchard's Avatar
Then your ECM isn't on... check your fuse in the engine bay
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
