Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
crap i need to weld on those SFCs ASAP
Old Oct 26, 2002 | 11:14 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Was just noticing that my body has bent quite a bit since early summer. I mean, the right t-top is looking more and more like an arch everyday I look at it. It looks like it's about to pop-up. Well, not really, but it's not exactly straight.
Wish I had a hard-top. But hell I know my body is flexing. My SFCs will help right?
Old Oct 26, 2002 | 12:12 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Your glass t-top is bending?
Old Oct 26, 2002 | 12:20 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
maybe he's got the Lexan t-top
Daz
Old Oct 26, 2002 | 12:29 PM
Daz
yes i have the lexan
Old Oct 26, 2002 | 12:46 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
or just some bad drugs..
Old Oct 26, 2002 | 01:49 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
So the lexan t-roof is flexing and then taking a set? It's staying flexed?
Old Oct 26, 2002 | 01:55 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
bent pins
Lexan roofs don't bend they get stress cracks if you would like to see what I mean checkout my t-roofs next time we get together. Lots and lots of stress cracks only visible from the inside.
The t-roof lock down pins, on the other hand, get loose when their guide slot starts to elongate from pressure on the body (twisting). Mine are looser since I started making more torque. It makes the roof ride 1-2mm higher. So I dissassembled them and put ducting tape around the plastic guides for the pins so there is no more slop. I'll have to get new roofs one day the guide slots are not a replaceable item. Be cheaper to get glass roofs which, by-the-way, also suffer from the same problem.
SFCs would make most of this problem go away.
RP.
Old Oct 26, 2002 | 02:00 PM
here's kinda how it looks right now. it's not this bad, but you can see that it is about 1-2 mm concaved....
Old Oct 26, 2002 | 03:37 PM
palric's Avatar
great pics
Good pics Alex.
I've had this problem before. If you dissassemble the receptacles for the t-roof locking pins (3 phillips screws) on the passenger side front pillar you will see a couple of 10mm bolts that hold the pin centering mechanism to the body. The centering mechanism is ovoid in shape and if you loosen the bolts you can move a 'cam' behind the pin brace this will have the effect of adjusting the roof up or down. In fact it moves the locking pin up and down so with it the t-roof. You should be able to get atleast a few mm's adjustment out of it. I did it last spring because my roof was sitting high and making alot of unneccessary wind noise.
Easy work EasySpeed get yer wrenchs out.
RP.
Old Oct 26, 2002 | 06:27 PM
Slade1's Avatar
Are you crazy Palric...?? that's too much info for the poor lad!
Nah, I have faith you can do it... just remember to wear a grounding strap before you work on your car hehe...
Alex, get them welded ASAP, it'll only get worse with the way you drive...
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
meeklay812
Oct 1, 2015 03:46 PM
