Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
CODES and lots of them..
Old Jul 21, 2005 | 04:45 PM
STIFFLER's Avatar
Ok guys I need some help on finding out these codes.
23 Mat Sensor Low voltage (Probally the relocation to the front air duct)
33 MAP Sensor High voltage
51 Faulty or improperly installed ECM PROM
I have switched ecm's (I have a spare) and memcals still comes on
41 Cylinder selection error (checked the firing order and it looks good)
I want to solve code 51 because it might help with others..
Any help would be appreciated
Old Jul 21, 2005 | 04:56 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
What year is the harness, PROM and MEMCAL?
Has any prom/memcal combo worked correctly with this harness?
Old Jul 21, 2005 | 05:00 PM
STIFFLER's Avatar
1992 Harness prom and memcal SD car
Yes this prom and memcal use to work on my old 305 combo but now that I have changed to a 350 I have all kinds of problems.
Old Jul 21, 2005 | 09:43 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Correct me if I'm wrong, you are using the 305 chip(prom) with the 350?
Old Jul 22, 2005 | 05:14 AM
STIFFLER's Avatar
Supposely they are the same.. so iam told by the DIY Prom guru's.
Old Jul 22, 2005 | 05:42 AM
Engine: SBC, LS-x
It has been reflashed with 350 code?
Even if it had the 305 code, it should still run, just not very good. Would be lean for sure.
Something must either be wrong with the flash or the IC. See if you can spot any bent legs/pins ect. Pull it out again and reseat it.
Old Jul 22, 2005 | 07:23 AM
STIFFLER's Avatar
Did some reading on the Grand National board about code 51 and it has something to do just starting your vehicle or applying power... I erased the codes and BINGO most of them are gone...
but I have 1 now code 43 ESC (Electronic spack Control) so something with my knock sensor which I am pretty sure is the wiring.. the wire was frayed pretty bad..
Hopefully the end is near...
Here's the sight about trouble codes... very good sight..
http://www.gnttype.org/maint/malf.html#23
Old Jul 22, 2005 | 08:59 AM
Engine: SBC, LS-x
It will generate a code 43 when the car is just started and the voltage is low. Its a test to see if it is fuctioning right.
I'd say your guess is right. My fan sw which is right there in that area and the wire was fairly cooked and brittle. It litterally fell apart in my hands.
Old Jul 22, 2005 | 04:17 PM
STIFFLER's Avatar
Well... this is crazy... If I erase the codes I get code 43.. rev the car up a little and all the original 4 codes come back.. what gives?
Mind you I haven't driven the car down the road yet... this is all in my garage.
specialized
Jun 18, 2022 09:26 AM
Toolsin
Feb 2, 2016 06:55 AM
92projectcamaro
Jan 18, 2016 08:00 AM
gta90
Sep 15, 2015 04:00 PM
ZZ42Fast
Aug 30, 2015 02:39 PM
