Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
TMP next Wednesday!
Old Jul 5, 2007 | 07:37 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
TMP next Wednesday!
Just waiting on tires that should arrive this Friday so next wednesday I'm heading down to TMP see what the LS1 has. I'm gonna see if I can break it hehe
Anyone else wanna go?
Old Jul 8, 2007 | 06:53 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Re: TMP next Wednesday!
I'm interested. Wednesday? Is it just T&T? Evening?
What exactly is 'Wild & Wicked wednesdays'?
Old Jul 9, 2007 | 06:53 AM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
As a child I learned 'breaking' things is a world of fun...
Old Jul 9, 2007 | 07:39 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Wild and Wicked Wednesdays is the new catchy name for test and tune but its been a few years since I've been so maybe its somewhat different I dunno.
I just want to know what shes got!
Old Jul 12, 2007 | 02:06 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
12.3 @ 115 smokin the friggin tires man i couldn't hook for ***** on a bun. Loads of fun but theres lots more in her. Some poor dude put his 9 second 68 Maro into the wall.... at speed. He was loose after the 1/8th and everyone was complaining about shitty track conditions. Had fun but definitely have to try again on a warmer day.
Still it was loads of fun
Old Jul 12, 2007 | 07:16 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Good deal Cam..that things got some power in it eh?
What new tires did you get?
I am sticking with drag radials all the time, unless it's a decent road trip.
Old Jul 12, 2007 | 08:08 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Ya it has all kinds of pull just no bite. I'm looking at the slip now and it was a 12.34 with a 1.98 60' on brand new 275/40 Mickey Thomson ET streets. I tired messing with tire pressure, varied launch RPM, bogging it, easing it out, everything short of pedaling it and it really made bupkiss difference. I ran 12.4 all night just blazing through first gear and a good chuck of second.
I was pretty surprised that it did not hook harder I have good suspension. Spohn adjustable TQA cross member mounted. LCA brackets set to the lowest hole. I dropped the front sway bar off too.
I think the gear was really hurting me as well. I built this car to be potent around road courses not drag strips so I chose 3.73 which is about perfect for driving but... I was BARELY hitting fourth through the traps. Some 410's would help the launch and get me through the traps in fourth at power.
I want to see that 11 so bad I might just do a gear swap but regardless I need to go on a Saturday when the track is prepped and there is some heat in the asphalt.
Old Jul 23, 2007 | 07:46 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I went back Sunday and ran a bunch of 12.7's in the heat again blowing off or bogging I finally found a combination that worked.
I swapped out the rear springs to give me more LCA angle ( I already had the relo brackets maxed out ) and dropped the tire pressure to 15psi and launched at 6K RPM and cut a 1.69 60' and made a 12.22 @ 113 MPH
I tried again at 7K and smoked em for 60' with a 1.89 60' but still managed a 12.22 again @114 MPH so if I could get that launch to hook I'd be golden... 7K hehehe gotta love that. Anyways..
So now if I can keep her hooking and get back out on a cooler night/day I think an 11 is within reach.
One of my first passes yesterday when i blew off the tires I hit an all time high 117 MPH. It heated up pretty good as the day wore on and my trap speeds slowed all day even when i was running the same 12.7's
Biggest factor for me was long looooong burnouts and low tire pressure combined with easing out the clutch and rolling on the throttle.
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
Logan Bryant
Sep 18, 2016 09:27 AM
92camaroJoe
Aug 13, 2015 06:07 AM
NJ SPEEDER
Theoretical and Street Racing
Jun 24, 2001 07:39 AM
