need help bad
Old Apr 21, 2002 | 10:03 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
need help bad
Well I have been trying to get my 83 to start for the last couple days. I got a Painless harness on it for 90-92 TPI.
I pulled a spark plug while it was cranking and it sparked.
I smelled fuel on the plug so I got fuel.
I know the wires are on the distributor correctly.
I am looking at the position of the valves and it seems to me that the rotor is pointing at the proper cylinder in the firing sequence.
the only thing I can think of is that the valves are too tight. but I didn't think I put them very tight at all. Does anyone have an ideas to shoot at me? any help is very well appreciated. Sorry for any information I forgot to tell but please ask any questions. thanks
Old Apr 21, 2002 | 10:31 PM
CamaroX84's Avatar
Did you check your fuel pressure by chance??
Old Apr 21, 2002 | 10:34 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
the fuel pressure holds pretty steady at around 50 when cranking.
Old Apr 21, 2002 | 10:43 PM
cherrybomb86's Avatar
heres what i did verify compression with a tester and adjust your valves accordingly around 120 psi youll know if your not building compression cause it will sound funny when turning over good luck guy
Old Apr 22, 2002 | 02:47 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I was just wondering how does the ECM know when to fire the injectors? Does it get some sort of feedback from the distributor? I am not getting enough putting to believe anything is really happeneing. I am getting spark becuase I pulled a plug and had my friend crank the motor and it sparked and it smelled like fuel. Is it at all possible for only a couple injectors to fire?
Also when I first turn the key forward and the pump primes the pressure goes up to 50 and then I hear the relay click and the pump shuts off then the pressure drops to 25 is this normal?
I was so eager to go fuel injection now Iw ish I just bolted on a carb. There are so many variables. thanks for any help guys
Old Apr 22, 2002 | 03:18 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
You messed up one thing and now you want a carb?? Maybe you should if you have that attitude.
Anyhow, maybe you set your distrubuter in incorrectly. check the timing. don't they make a small light that can allow you to see if the inj. are firing??
Old Apr 22, 2002 | 05:45 PM
88ROC1LE's Avatar
sure the firing order and plug wire order is correct. I would double check if you have o.k. Just trying to help
Old Apr 22, 2002 | 06:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The distributor could be out 180 degrees. To check, turn engine over until rotor points at #1 spark tower on cap & the timing mark is @ 0 degrees on the balancer. Remove valve cover & make sure both intake & exhaust valves are closed (rockers up) If not the distributor is installed wrong.
Old Apr 22, 2002 | 08:00 PM
dont screw yourself buddy pull #1 plug ans stuff a tissue in it. crank the starter with the cap off and disconnetcted when the tissue pops out your on comp stroke. take a breaker bar and turn the crank clockwise till you get close to the timing tab check the position of the rotor in regards to the number terminal if your anywhere close your ok and firuther adjustments may be made by turning the cap sounds like everythin is functionioning properly dont be afraid if you have any further questions :lala:
Old Apr 22, 2002 | 08:30 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
wow calm down. I was just kidding
I have checked the order of the wires like 20 times so that is right on the cap. I am going to mess with being positve I got it on TDC for number 1
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
