9th injector and StealthRam?
Old May 12, 2002 | 10:34 PM
FormulaGod's Avatar
How do i go about his problem? I tried looking for the answer w/ no avail. What do i do about it? :hail:
Old May 12, 2002 | 10:48 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: 9th injector and StealthRam?
This thread may help you. I have SD so it wasn't a problem for me.
http://www.chevytalk.org/forums/Foru...ML/000626.html
Old May 13, 2002 | 12:06 AM
cfabe's Avatar
Convert to speed density or a later MAF setup that didnt use the cold start (89 i think). Or you could just leave it out if you dont drive it when its real cold out.
Old May 13, 2002 | 05:40 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, convert your prom to 1989 programming. You will have to get a custom prom anyway to take advantage of the HSR anyway.
Old May 13, 2002 | 12:01 PM
FormulaGod's Avatar
John,
Convert to 89 Prom? Do you mean change the tables so the comp squirts fuel at startup like the SD? If so, do i just remove the 9th injector altogether. Thanks..
-paul
Old May 13, 2002 | 12:59 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
John,
-paul
That's pretty much the idea. The 89 is the exact same MAF system that you already have, except they smartened up and removed the CSI and just richened the tables at startup.
Old May 13, 2002 | 01:04 PM
FormulaGod's Avatar
Thanks JIM!!!! :hail: :hail: :hail: :hail: :hail: :hail: :hail:
Old May 13, 2002 | 03:36 PM
JucinGTA's Avatar
I ran all last summer without my ColdStart, it just takes a few more cranks to get it started, no biggy!
Old May 13, 2002 | 03:39 PM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
I ran for years w/o the CSI on my 87 before I knew anything about PROM changes.... so it wont hurt to run w/o it...
Rick
Old May 21, 2002 | 10:03 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
so if Im converting my car to the LT1 Intake, done by the guy at LT1intake.com,the LT1 is just like the HSR in both not having a 9th injector. John is going to burn me a new prom to take advantage of the new intake and no EGR, will he have to do an '89 prom
and wil I just remove the injector and then tuck the wire for the injector somewhere not connected?
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
