Stealth Ram flow #'s & Gasket sizing...
Old May 13, 2002 | 06:17 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Hey guys,
Could anyone measure their Stealth Ram's intake manifold port sizes? I've got some AFR 210's ported to a Felpro 1206 intake manifold gasket, and was wondering if the Stealthram could be ported to match. The LT1's are a stretch, as is the SuperRam that's on there currently. I know the MiniRam II can be ordered that way, but I'd like to avoid the flow distribution issues with big cfm airflows. Does anyone also have flow numbers? I'm concerned about this being a bottleneck compared to an EFI'd Victor Junior or the Accel single plane efi. Yes, I have searched the archives Thanks!
Old May 13, 2002 | 06:34 AM
ImportsRsloths's Avatar
A THIRD GEN ***!!!!! :hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail:
Old May 13, 2002 | 07:46 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Andris, in unported condition the stealth ram is supposed to flow approximately 300cfm. I've heard that it can easily be ported to match a 1205 and if I recall correctly, may need additional material welded to match a 1206. For a better answer, try posting in the EFI board of chevytalk.org. The moderator there is a Holley guy that's involved in the development of the stealthram.
Old May 13, 2002 | 08:50 AM
Guido's Avatar
Car: 2000 Trans Am
WTF?
Old May 13, 2002 | 12:53 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Hey check it out, I did like a quick measure, don't know how accurate this is, but I put up a set of intake manifold gaskets, and it's like a perfect match. It's like their ported to the size of a gasket, a did a little comparison to a extra set of heads, and it the ports look like the same also. Like I said I didn't get bust out the tape measure just looked by eye and compared.
Old May 13, 2002 | 12:58 PM
Jim85IROC's Avatar
what gasket? 1204, 1205, 1206, what?
Old May 13, 2002 | 06:29 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Oh my bad Jim, I m not sure i have to ask my buddy they were his, he's got them for his motor that he's building, Their something special, suppose to be better then normal ones, I' ll get it in a few mins.
Old May 13, 2002 | 06:42 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Clevite 44456qp, those are the gaskets that he has. And that was the one that I compare to the SR and it was almost a perfect macth. The SR's ports are hugh compare to the stock tpi. Oh those gaskets came in some kind of kit or something like that, thats the part number off the gasket. Wish I could be more help.
Old May 13, 2002 | 06:57 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
alright i just measured mine with the tape measure 1inch'3/16 wide, 1inch 15/16 tall.
Old May 13, 2002 | 09:45 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Originally posted by Guido
WTF?
I'm guessing he posted that Skulte's a Thirdgen G O D. For some stupid reason you can't post *** on this board.
Old May 13, 2002 | 10:50 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Andris,
https://www.thirdgen.org/techbb2/sho...hreadid=101299
Tim
Old May 14, 2002 | 01:44 AM
Bort62's Avatar
Beat me to It there Tim-bo.
Haha, I called you Tim-bo In public
Old May 14, 2002 | 03:38 PM
JucinGTA's Avatar
Pooo!! Actions site say they recommend a 1206
Intake Port Gasket Felpro 1206
Old May 14, 2002 | 04:40 PM
89ProchargedROC's Avatar
if you have a good head porter.....they can make big intake ports on heads fit a small gasket
Old May 14, 2002 | 05:34 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Wait a minute. It really isn't a big issue going from a bit smaller port into a larger port. Yes, it isn't ideal, but it isn't a restriction like going from a bigger port to a smaller port.
I don't think the difference from a 1205 to a 1206 is that huge. I have wrestled with this same thing because I have a SR, an Edelbrock Hi-Flo Baseplate and I just bought the Pro Action heads (yes they require the 1206)
After talking to a few local people here, I should be ok. It isn't like the fuel will completely drop out of the stream and puddle at the start of the intake runner.
I am going to port match to the 1205 and use the 1206....I am not going to add material to the intake baseplate.
L98GTA87
Oct 19, 2015 10:43 PM
84redta
Sep 19, 2015 09:58 AM
R3500
Sep 8, 2015 10:12 PM
hdis2002
Sep 8, 2015 02:52 PM
09ave
Sep 7, 2015 06:03 PM
