Anybody using the holley throttle body?
Old May 19, 2002 | 12:27 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I managed to break one of the bolts off in the hole of my throttle body when trying to remove the piece that the IAC is attached to from the bottom of the throttle body. I've been looking for an excuse to get a new one, and this seems as good as any. I've heard that the BBK is cheap, plus the rough cast finish doesn't match my polished setup, and because of its shape, polishing would be cumbersome to say the least. The holley TB comes fully polished and looks like a quality piece. So... anybody have any experiences with them? I'd be looking at the 52mm TB.
Old May 19, 2002 | 03:49 PM
rhuarc30's Avatar
Haven't used 'em but Holley makes pretty good products in general. They also make one with built in nitrous ports, under the NOS brand name, so if your thinking about adding nitrous in the future, you might want to look at it as well.
Old May 19, 2002 | 06:48 PM
JAY87GTA's Avatar
I have one, bought for the same reason as you. My bleed air screw broke on mine. Oustanding polish job on it and the machine work is first rate. I cleaned up the IAC housing before I put it on, and had to grind the end of the TPS arm for clearance when I put it on.
Old May 20, 2002 | 06:30 PM
87GTA_409's Avatar
I do not know about the 52mm TB of Holley, but the 58mm I got from Holley was a total POS! It did not have a a possitive stop for WOT (it would rotate to 120deg!). It did not have enough clearance for the TPS to rotate (about 30 minutes with a file solved this problem). It did not come with the right bolts (wrong thread pitch for the plenum and the stockers are not long enough, so off to the hardware store I went). The throtle cable connection is mounted higher and farther forward. This is not a problem with a standard TPI set-up, but with the TPIS mini-ram it makes the off idle step-in very jerky. The spring tension on the throtle body is way too stiff (it is adjustable with three different holes, but I had to add a forth hole to get the throtle pressure where I want it). I hope you have better results with your TB.
thanx
G
Old May 20, 2002 | 06:39 PM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
i have a 52mm holley tb. and the only 2 things wrong was the tv cable connctor was to big.& i had to grind my tps sensor down. other than that great.
Old May 20, 2002 | 06:40 PM
GhostBuster's Avatar
I want a droddle body but i heard they night move too much air? Help i want to go vrooooom
Old May 20, 2002 | 07:08 PM
bobs89irocz's Avatar
I have a 58mm tb from holley, i love it. It looks sweet and i have had no problems with it except for it being so $$$$
Old May 21, 2002 | 09:52 AM
camaro6spd's Avatar
is it me or does GhostBuster sound like he is about 5. All of his posts are soo bad that you can hardly read them. I am not one to talk but at least the people who read my post know what i am trying to say. varoom???
Sorry needed to vent.
Old May 21, 2002 | 10:08 AM
YRUSOSLO's Avatar
I have one slightly used for sale. I've replaced it with a Commander 950 that's why I'm selling it. My 305 didn't like telling the Holley what to do. I can't remember if it was a 58 or a 52.
Old May 21, 2002 | 10:30 AM
V8Steve's Avatar
BBK
See my post below about problems with my ZZ4. The BBK inlet is cast and this area looks like it was made by Fed Flintstone.
Old May 21, 2002 | 10:43 AM
Jim85IROC's Avatar
Ordered a brand new holley 52 last night.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
