90-92 guys: Where is MAP sensor
Old May 23, 2002 | 11:44 AM
AlexJH's Avatar
Engine: 5.7L V8
Hello my speed density friends, I'm converting my MAF car to MAP and I'm wondering where the vacuum source for the MAP sensor comes from.
If anyone has a pic of the mounting of the MAP sensor, that would be awesome!!
Old May 23, 2002 | 11:59 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
On my 90, it's a small black unit attached to the passenger's side of the plenum with 1 bolt. The vacuum line runs underneath the plenum. Sorry, no pics, I'm at work.
Old May 23, 2002 | 12:06 PM
Camar_Hunter_c's Avatar
Sometimes attached to the passanger side firewall too.
Old May 23, 2002 | 12:52 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I have no good pictures but on my 92, as Synapsis said, it's attached to the pass rear of the plenum with one 10mm bolt. The vacuum source is a nipple on the plenum by the fpr plenum nipple.
Old May 23, 2002 | 01:11 PM
I guess I shoulda mentioned that was on My V6.. But I have seen stranger things...
Old May 23, 2002 | 08:15 PM
Swapmaster's Avatar
Just mount it to the firewall and tee into the vacuum line for the
fuel regulator.
Old May 24, 2002 | 12:02 PM
AlexJH's Avatar
Engine: 5.7L V8
That's what I was thinking swapmaster. There will be a nice empty spot from where my MAF relays were.
Old May 24, 2002 | 05:21 PM
90Form350's Avatar
yeah, there is a third nipple for the map sensor on 90-92 plenums.
Old May 26, 2002 | 02:13 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
You need to keep the hose as short as possible to prevent delayed reactions from the ECM
meeklay812
Oct 1, 2015 03:46 PM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
