Delete A/C and AIR pump in serp belt setup ???
Old Jun 3, 2002 | 08:52 PM
TVP's Avatar
TVP
now here's a crazy thought !! ... use a 66-70" belt and route like pictured .. if it links :\ pardon the stolen pix and bad sketch .... you have to switch to the old style water pump because it rotates the "other" way ... ????
Attached Thumbnails Delete A/C and AIR pump in serp belt setup ???-belt2.jpg
Old Jun 3, 2002 | 11:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
sounds good but how do i ditch my whole pass side bracket? Thats what i'm tyring to find out.
Old Jun 4, 2002 | 07:37 AM
TVP's Avatar
TVP
I was thinking about that .. need a bracket to hold the
tensioner :\ ....
TVP
Old Jun 4, 2002 | 01:49 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
That's an interesting thought, but I'm not seeing how it requires the use of the old standard-rotation water pump. You can clearly see by looking at it that belt will rotate the water pump in the opposite direction from the crank, which is the same as factory.
In fact, your routing is very close to the factory style routing except for how it handles the tensioner. I can see three problems there: 1), the tensioner is now rotating in the opposite direction; 2) The ribbed part of the belt is toward the tensioner rather than the smooth part; 3) the angle of the force imparted on the belt tensioner has changed.
Old Jun 4, 2002 | 04:12 PM
DM91RS's Avatar
Car: 91 RS
You gotta use your imagination........
Old Jun 4, 2002 | 04:14 PM
DM91RS's Avatar
Car: 91 RS
Oh yeah........what's this have to do with tpi?
Old Jun 4, 2002 | 04:17 PM
Blackened's Avatar
You're the one posting pics buddy...! lol
Old Jun 4, 2002 | 07:46 PM
DM91RS's Avatar
Car: 91 RS
Yeah...that's what I meant. Just happened to remember what board this was .... .... lol
Old Jun 4, 2002 | 09:00 PM
TVP's Avatar
TVP
back to that pix !! fab'ed brackets ??
TVP
Old Jun 5, 2002 | 03:17 PM
DM91RS's Avatar
Car: 91 RS
TVP
Did Reese *** win any races with those parts that you have from his setup?
evilstuie
Jan 9, 2020 08:29 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
BikeFarm
Aug 11, 2015 11:35 PM
