How difficult would it be to swap a 350 TPI in place of a 305TBI on a 91' Camaro??
Old Jun 4, 2002 | 10:18 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm interested in making the swap but how difficult would it be?? As far as bolting on accesaries like steering pump, A/C, alt and so on is it just a matter of swapping from one motor to the other, will the brackets from my 305 fit the 350?? What about throttle cable and TV cable are they the same as used with the TPI? Mainly what I'm concerned with is can I just pull my TBI 305 and install a 350TPI and just bolt everything right up or are there differences between the 2 motors. I know the computer won't work, will I have to buy a new computer or can I just replace the chip so that it will work with a TPI. I also know that a new wiring harness will be needed.
Old Jun 4, 2002 | 11:12 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You will need the computer & engine wiring harness from the TPI car as well as the alternator bracket. The best option is to get everything from a donor car. 305 TPI uses the same parts as a 350 with the exception of injectors, PROM & knock sensor.
Old Jun 4, 2002 | 12:54 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
How much do you figure a donor motor with harness and computer out of a 91' Camaro would run me??
Old Jun 4, 2002 | 05:39 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I did it in my '89....305 TBI to 350TPI...but I didn't do it all at once or have a donor car....it's pretty easy, just a lot of $$$. You will need the things he said above...but I didn't need a different alternator bracket?? I've heard some people say you do, some say you dont, i didn't. You will need of course the motor w/ TPI and TPI accessories, wiring harness, computer, TPI fuel pump, kickdown cable, acc. cable, knock sensor....that's all I can think of off the top of my head. Like he said...be a lot easier to get a donor car.
Old Jun 5, 2002 | 07:39 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
why?
the brakets are the same.
also make sure you get a engine harness out of a 90-92 TPI car it'll make life much eazier.beleve me i just put a 89 5.7 TPI in my 91 5.0 TBI car.very time and monye consuming but in the end it'll be well worth it.
Old Jun 5, 2002 | 09:08 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Can anyone give an idea of how much money is involved in making a swap like this??
Old Jun 5, 2002 | 09:33 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I have spent well over $5,000 on my swap, but not much is stock and I did not have a donor car. The harness was bought new from GM and was really easy to swap.
Old Jun 5, 2002 | 10:10 AM
91banditt2's Avatar
Engine: 5.7 HSR
do your self a favor and visit this web site
www.chevythunder.com
Leonerd has alot of usefull info
you could also send your TBI wiring harness and he'll convert it to what you need.
CHEAP!!!!!!!!!!
$176 for a converted harness or
$500 for a brand new GM harness
you deside
Old Jun 5, 2002 | 11:47 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
don't forget about the fuel pump, they are different i believe
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
