Lt4 hot cam and Afr heads
Old Jun 19, 2002 | 01:15 PM
91 z28 350's Avatar
Car: 91 Z28
will the LT4 Hot Cam and the Afr 190cc heads work well together ? Also i was thinking about getting the Fast burn heads are these heads good ?? Or maybe even vortech heads. Which ones will give me the best bang for my buck
Old Jun 19, 2002 | 04:19 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
The vortech heads will require you change the intake manifold as it is not the standard intake bolt pattern. If I remember correctly, the fast burn heads have the same intake pattern as the vortech heads and will not work with the tpi intake or the SD vortech tpi base. The AFR heads and the LT4 hot cam will be a good combination in my book.
Old Jun 19, 2002 | 04:33 PM
91 z28 350's Avatar
Car: 91 Z28
Where can i get Afr heads for a good price ?
Old Jun 19, 2002 | 04:56 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Z-racing has the best prices that I know of. Heres the site
http://www.users.qwest.net/~zjon/z-racing/
Old Jun 19, 2002 | 06:21 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
He's right....the vortecs and fast burns have a different bolt pattern...and you have to buy the $400 manifold to go w/ them. So if you got the fastburns, it would run you about $1500 for heads and manifold. The vortecs are only $450....plus the $400 manifold.....$850 for the vortecs and manifold...that's not bad at all. The AFRs and HOT cam make a PERFECT combo....but the AFRs will run you upward of $1500...about $1250 for the heads, then you gotta get a hole drilled for the fan switch, get the heads milled to get the correct combustion chamber, and something else I can't remember....will run you $1500-$1700 w/ shipping....but then you gotta either siamese the intake manifold to handle the flow, or by an aftermarket for $300. The AFRs w/ HOT cam would give you the most power, but for a LOT more than the vortecs and vortec manifold.
Old Jun 19, 2002 | 08:22 PM
91 z28 350's Avatar
Car: 91 Z28
So how will the lt4 hot cam work with the vortech heads and the fast burns ?? Afrs are outta my price range
Old Jun 19, 2002 | 08:52 PM
91 z28 350's Avatar
Car: 91 Z28
1. L31 Vortec Heads - Assembled
$238.75 $477.50
Part Number 12558060
2. TPI Vortec Lower Intake Baseplate
$399.95 $399.95
Part Number 12498060
3. LT4 Hot Cam
$175.50 $175.50
Part Number 24502586
Shipping and Handling: $24.75
Grand Total: $1,077.70
Is this a good price for this stuff ?
Old Jun 19, 2002 | 08:53 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I got the same combo. AFRs 190+LT4 HC. I got my AFRs from this site www.tenperf.com. Dave of tenperf.com was recomended to me by moderator Willie, on this site and I think he has the best prices according to my research. I paid $1450 for a set w/all the exta drillings and stuff for TPI, but I had mine milled to 64cc chambers($150). Other than that he'll sell you a set for $1300 shipped. That's not bad sinse shipping is usually about $60-70, so it does figure into the price.
Old Jun 19, 2002 | 08:54 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Yes....the HOT cam will work w/ both of em. And if you get the heads bare, just make sure you buy springs that will handle the lift....but if you buy em assembled, you dont have to worry about that.
Old Jun 19, 2002 | 08:59 PM
91 z28 350's Avatar
Car: 91 Z28
oh yeah one more thing will I need a custom Chip for all this ???
Old Jun 19, 2002 | 09:04 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
If you want the best possible performance, then the answer is yes. My friend swapped in a LT4 hot cam in a 305 and it ran way too rich even with the Adjustable fuel pressure regulator. It may not run up to 100% without a custom burn chip.
Old Jun 19, 2002 | 09:09 PM
jms's Avatar
jms
My Fast Burn heads have both intake bolt patterns. Vortec and old style.
jms
Old Jun 20, 2002 | 04:14 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
$238.75 $477.50
$399.95 $399.95
3. LT4 Hot Cam
$175.50 $175.50
YES that's a good price.....$1,077 for heads, cam and intake....you can't beat that. Most aftermarket heads alone are $1100 plus. And Derfrank is right....to get your car to run like you'd like it, you'll need a chip burned.
Old Jun 21, 2002 | 11:12 AM
HatchetJack's Avatar
The L31 heads need some work for this--studs changed or at least pinned, top of valve guides cut. You also are overlooking the price of springs, retainers, special bolts for those heads, and don't forget the 1.6 rockers that hot cam is rated with.
Get the AFR's or you always will wish you did and spend the rest of your days explaining how your set is "just about as good as AFR heads"!!---
Check out the price for the hot cam and kit from Chev as this is a real deal for matched components from someone you can trust.
Old Jun 21, 2002 | 11:29 AM
91 z28 350's Avatar
Car: 91 Z28
The hot cam kit is 500
Old Jun 22, 2002 | 12:29 AM
Still cheap for roller rockers, quality springs, light retainers, and the cam----You need this stuff to make the L31's work with the cam or run something else. The price you are looking at for the vortecs is for the non-upgraded head and you will need better springs anyway and what about rockers???? Thats what makes the kit so appealing. I went with AFR's even though it was hard to justify at the time---every time I think about it now I know I made the right choice!
I am putting together another motor with vortecs and the hot cam kit. Will be carbed for a 84 Z. So I have delt with both combo's. The vortecs aren't such a deal when one sets them up right and buys the extra stuff.
Good luck whatever you deciede------Jack
Old Jun 22, 2002 | 04:05 PM
91 z28 350's Avatar
Car: 91 Z28
I think i'll just get the Afr's
evilstuie
Jan 9, 2020 08:29 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
