Hey 406 guys
Old 06-29-2002, 08:51 PM
93ND500's Avatar
Hey 406 guys
Tell me what you think.....should this wake up my C1500 or what.
Old 06-29-2002, 09:35 PM
Blackened's Avatar
Just because it's pretty doesn't mean it's powerful
Old 06-29-2002, 09:41 PM
93ND500's Avatar
...spoil sport........DD2000 has it at in the 500HP range. So I would easily expect it to hit over 400HP in real life.
Old 06-29-2002, 09:47 PM
Blackened's Avatar
Oh.. well... in THAT case... that's not bad
Old 06-29-2002, 11:28 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
93ND500
What's with the 'spacers' between the runners and plenum....just curious.
Old 06-30-2002, 12:03 AM
egmonster's Avatar
I dig the cylinder head covers. Very nice indeed
Never been much of a Superram fan myself but if you have to be smog legal it definately is a nice way to go .
Old 06-30-2002, 12:34 AM
93ND500's Avatar
Originally posted by IROCZZ3
93ND500
Thoses spacers were made to install NOS Fogger Soft Plume nozzles.
Old 06-30-2002, 07:56 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Neah..that thing wont fit in your truck... best lend it to me to put into my Malibu... lol Me wishes we had the $$ for one. cheers, Bob
Old 06-30-2002, 08:48 AM
IROCZZ3's Avatar
Car: 87 Buick GN
:rockon:
Old 06-30-2002, 03:53 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
What are the cam specs and what are you using for exhaust? Also, what ECM and fuel injectors are you using? I am a bit skeptical of DD's numbers...just look at the newest Car Craft and what they need to get 500 HP from that engine with a solid roller cam.
I couldn't find that info on your site...
I have a Super ram too with an Edelbrock base and am considering a Stealth Ram when I swap the Pro Action heads on.
Old 06-30-2002, 08:58 PM
93ND500's Avatar
I don't trust DD2000's numbers much myself...that's why when it said upper 480-490 I took it as 400-410. I'll get the cam specs and stuff when I get to work.
Old 07-02-2002, 01:33 PM
Engine: LS3
Transmission: 6L80E
TTT...
Still looking for those specs
Old 07-02-2002, 03:32 PM
93ND500's Avatar
DP
Old 07-02-2002, 03:39 PM
93ND500's Avatar
TTT...
-400 @ .030 over (406).
-200cc Dart Pro-1 heads, 64cc chambers, port and polish / aggressive on the exhaust side.
-Comp Cams Extreme Marine cam, XM270***.
-Comp Cams 1.6 Magnum full roller rockers.
-Forged Eagle bottom end.
-JE pistons yielding 10.2:1 comp.
-Accel Super Ram EFI, 36# injectors, nitrous injection plates(150 shot).
-SLP headers......I know, I know....but my full length Hookers won't be here in time for the Sport Truck Shootout.
*** cam @ .050"
226/236
.512/.521 using the 1.6 rockers
112* LSA
110* CL
I don't know if this with or with out the nitrous data....The shop is closed untill after the holiday(vacation).
Old 07-02-2002, 04:35 PM
Engine: LS3
Transmission: 6L80E
My guess would be close to 450 HP without Nitrous. That is a fairly mild cam and those heads, while flowing ok, aren't the best heads in that intake runner size. But they are comparable to the budget trick flow heads.
I like your setup.
Here is what mine will be-
406
-stock crank, cast pistons, stock rods with ARP bolts
-Pro Action Aluminum Lightning 220 cc intake runner heads with CNC chambers
-Either Stealth Ram (just ordered) or Super Ram (have in Garage)
-MAF setup (possible switch to '730 in the near future)
-30# SVO injectors
-1 5/8" headers with custom y-pipe to single 3" mandrel bent pipe all the way back to Hooker Aerochamber 3" in/3"out and no cat
-Comp. ratio 10:1 (roughly, within .2)
-Cam is hydraulic flat tappet. 222 I @.500 and 226 E with 112 LSA and total lift .480.
-Stock TB
-Crane Blazer Full Roller Rockers 1.5 ratio
The rebuilt shortblock has only about 1500 miles on it and a redline of 5900 rpm. I decided that I am just going to bolt the upper end on and see what I get. Those heads are a bit big for the current cam and will easily support 500 HP. But I am kind of curious to see how the above combo will work. I think 450 HP is attainable...we shall see.
I have also an ACT 2600 stall 9.5" convertor and Pro-Built Trans to put in. Lots to do coming up.
Old 07-03-2002, 10:41 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
should be awesome man!! SuperRam'd engines are Torque monsters and in a truck thats exactly what u want torque.. u wanna be able to rip trees out of the ground lol..
Old 07-04-2002, 11:29 PM
egmonster's Avatar
The superram maybe a torque monster but the heads definately are not. Still a pretty nice setup. You will make good power, and I assume this is more a race truck than a work truck anyway so
Old 07-07-2002, 03:59 AM
rezinn's Avatar
Have fun pulling the top off of that superram once it's in the car to run the throttle cables.
Old 07-07-2002, 05:02 AM
93ND500's Avatar
The lid is not even bolted down yet....it's just sitting there.
Red iroc-z 305
09-30-2015 05:22 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
matthew911
08-12-2015 09:38 AM
mx127
08-10-2015 08:13 AM
Quick Reply: Hey 406 guys
