Runs like crap when cold
Old Jul 22, 2002 | 09:08 AM
Brian'sIROC's Avatar
My 88 305 TPI runs like crap when its cold. I thought these cars were supposed to run pretty decent when cold. Is there anything that could be causing this?
Old Jul 22, 2002 | 09:41 AM
tpi_roc's Avatar
Is your "Service engine soon" light on?
Old Jul 22, 2002 | 11:28 AM
Once in a while it'll throw a code 34. It will only throw this code if there's a slight miss when I first start it up. Other than that it always runs like crap when cold. Light or no light.
Old Jul 22, 2002 | 03:29 PM
Any other suggestions? IAC valve? Cold start injector?
Old Jul 22, 2002 | 03:31 PM
tpi_roc's Avatar
well I can guess all day, but to make sure it was asked first, do you have access to a scan tool?
Old Jul 22, 2002 | 03:38 PM
No, not at this time. Possibly over the weekend. What should I check?
Old Jul 22, 2002 | 03:41 PM
tpi_roc's Avatar
get it up to temp, and check the 02 voltage, you want it to be as close to .450mv in closed loop, and at the hotter temps of open loop, dont expect it to be between 400-500 steady because it wont, but if its always 200mv or or 800 then thats a sign, make sure ALL THE SENSORS are giving you some sort of output, and make sure it looks reasonable, also check other things like timing, knock, etc etc etc.
Old Jul 22, 2002 | 05:02 PM
Thanks for the suggestions, I'll check them on a scan tool this weekend. If the 02 sensor or any of the other sensors were bad wouldn't it always run bad? Once the car warms up it's fine.
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
drathaar907
Aug 6, 2015 04:20 PM
