Help with new motor. Please!!
Old Aug 6, 2002 | 07:05 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
I just rebuilt it and have aluminum heads and new cam stock TPI intake and injectors. It runs really hot. Cant even touch the strut tower brace or the spark plug wires, should it be this hot. It runs pretty good a little rough but good.
Thanks, Gary
Old Aug 6, 2002 | 07:20 PM
kevinc's Avatar
Car: 1982 Z28
Go back and re-check your initial spark timing, with the EST connector disconnected. Retarded spark will blow unburnt fuel out the exhaust ports, generating more heat at the manifolds/headers.
You didn't mention what the temp gauge was reading...
Old Aug 6, 2002 | 08:49 PM
BenDoe91z28's Avatar
the use of aluminum heads will increase underhood temperatures do to their thermal inefficiency
Old Aug 6, 2002 | 08:57 PM
fattie92's Avatar
running a cat?? check to make sure its not clogged
Old Aug 7, 2002 | 12:43 AM
Morley's Avatar
Pardon? Aluminum has greater thermal efficency than cast iron, which is why you can run higher compression on pump gas with alum heads. Also why they use it in radiators.
Old Aug 7, 2002 | 07:45 AM
S10Wildside's Avatar
The temp gauge is reading what?
Old Aug 7, 2002 | 07:09 PM
Engine: L98 350
The timing is right I just didnt know if it should run that hot. The temp gauge is normal most of the time, when i am not stuck in traffic. I thought it might be the heads but wasnt sure i know i might be running a little lean but i have no clue as to why. I just had it smogged tested without the smog pump or AIR tube hooked up and it passed so i think there is definately something wrong somewhere.
Thanks, gary
Old Aug 7, 2002 | 07:22 PM
Jza's Avatar
Jza
Wow.. aluminum heads are thermally inefficient, huh?
Rousseau92maro
Feb 1, 2016 05:12 PM
hartsmike
Oct 4, 2015 01:00 PM
customblackbird
Oct 1, 2015 04:30 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
KCG
Sep 23, 2015 09:05 AM
