IROC Problems??? Stumped
Old Aug 17, 2002 | 04:07 PM
Trent257's Avatar
well since i got my iroc, things have been going good. well now i was driving along and i tryed speeding up, and i got nothing, and it kept getting worse and worse, it jerks, it doesnt want to shift, right and my gas milage was horrid. now she tops out at 35mph, theres a loud noise coming from way back on the drivers side, maybee neer the transmission. fuel pressure is up around 45psi, any ideas where i can start?
ive recently changed the plugs, wires, cap rotor, fuel filter so those are all good
Old Aug 18, 2002 | 03:09 AM
rezinn's Avatar
I read this same exact post before, what happened to your last thread?
Old Aug 18, 2002 | 03:14 AM
rezinn's Avatar
Well I searched and found a few similar posts, sorry you haven't had any luck.
How does the car rev in park or neutral? What happened before the car's performance went sour? How do the electrodes on the plugs look now?
Old Aug 18, 2002 | 03:18 AM
Trent257's Avatar
sorry, i posted in another section too, but i am stumped with this one. reving in neutral it still sounds like loud air is comming from somewhere, all he plugs are fairly new...
Old Aug 18, 2002 | 08:09 PM
xformula79's Avatar
Do you get trouble codes? Or have you checked the TPS voltage?
Old Aug 18, 2002 | 11:06 PM
Gruvin84SS's Avatar
plugged catylitic converter?
Old Aug 18, 2002 | 11:11 PM
Trent257's Avatar
how do i check the tps voltage???
and how can i check for a plugged cataletic converter, or do i have to cut it off?
Old Aug 19, 2002 | 07:41 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm with Gruvin....
Sounds like a plugged exhaust system.
Old Aug 19, 2002 | 12:02 PM
Trent257's Avatar
well i looked under and my o2 sensor was hanging there and the loud noise was coming from the 02 sensor hole, would that cause my car not to run?
Old Aug 19, 2002 | 02:09 PM
fastvetteTPI84's Avatar
yeah thats not good if the 02 is not in the hole it will give the ecu all kinds of wrong readings being that it doesn't warm up fro m the exaust even a small pin hole or so will make the car run like crap because of the outside air geting to close to the o2 ....fix the hole replace the o2
Old Aug 19, 2002 | 04:17 PM
Trent257's Avatar
well it was a plugged cat, it should be ok now, im welding a new one up
Fronzizzle
Aug 17, 2015 02:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Elliswon
Aug 10, 2015 12:33 PM
Fronzizzle
Aug 9, 2015 01:15 PM
