anyone wanna help me pick a cam?
Old Aug 26, 2002 | 05:24 PM
cobrakiller1989's Avatar
my setup is...
355
9.5:1 CR
world products heads with 2.02/1.60 valves and 170cc intake runners
holley stealth ram
new 700r4 with 2800 stall
3.73 rear
let me know if i left out anything important..
it needs to be streetable and will also be backed up by a 150 shot of nitrous once in a while
Ill be tuning this as setup as soon as i learn how to, i just got the equipment. Right now im kinda leaning towards the LT4 hotcam. but im open for suggestions, im probably not gonna do the swap for a few more months
let me know what you guys think.
thanks
Old Aug 27, 2002 | 05:50 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I think the hot cam will work well with that intake.
Old Aug 27, 2002 | 08:12 PM
esams's Avatar
That hotcam certainly can't be a bad choice. Here's what I'd do, choose the cam around the torque converter and gear if you already have them. What converter is it? That will help us nail the cam.
An '86Z here in SLC with a 350, Fastburn heads, hotcam, Holley Commander 950 and 9 pounds of ATI intercooled boost just dynoed 560 hp at the WHEELS!:hail:
Old Aug 27, 2002 | 08:20 PM
Im not sure what kind of converter it is, but my trans guy(freind of my family) said it is a high density converter or something. sorry i really know nothing about transmissions or converters. when i put my foot on the brake and gas at the line at the track it will stall up to 2600 tho. what is the hotcam's powerband?
Old Aug 27, 2002 | 08:24 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I asked the same question over at ChevyTalk.com & Doug Flynn from Holley recomended a cam very close to the one I have, a Comp Extreme Energy XR276HR, in fact he felt it would work very well.
Old Aug 27, 2002 | 08:53 PM
esams's Avatar
The carbed setups with Vortec heads and the hotcam peak as high as 6k, don't they? (only 80% sure on that one) You might as well be the sacrificial lamb for the Stealth/hotcam setup man. Then when you get it all tuned and dynoed, you can always throw out that converter and get a custom built Yank or Vigilante that'll get you another 3 tenths with full traction.
Old Aug 27, 2002 | 09:23 PM
good point, as soon as i pay off my debt im getting a hotcam then
Old Aug 27, 2002 | 09:56 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
When I was going to build a TPI'd 355, my engine builder called CompCams and ordered a cam which is now in my carbed 355 (DON'T ASK). It is a 262 grind....214/224 duration and .480/.480 lift, 112* LSA. It was supposed to run really well with a TPI setup and stock PROM. I didn't do the swap because I had a lot of electrical problems. I would definitely recommend that cam for you, though.
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
